Main structure storing the parameter settings. More...
#include <cs_equation_system_param.h>
Data Fields | |
Generic metadata | |
char *restrict | name |
int | verbosity |
cs_param_space_scheme_t | space_scheme |
int | block_var_dim |
Linear algebra (SLES) | |
bool | sles_setup_done |
cs_equation_system_sles_strategy_t | sles_strategy |
cs_iter_algo_param_t | linear_solver |
block_var_dim |
Dimension of the variable in each block
linear_solver |
Set of parameters to control the (main) linear solver
name |
Name of the system of equations
sles_setup_done |
Indicator to know if the setup stage has be done
sles_strategy |
Type of strategy used to solve the resulting system
space_scheme |
Associated space discretization. One assumes that all blocks share the same space discretization.
verbosity |
Level of verbosity (quantity of output information)
