7.2
cs_cdo_system_helper_t Struct Reference
#include <cs_cdo_system.h>
+ Collaboration diagram for cs_cdo_system_helper_t:
Data Fields
cs_cdo_system_type_t type
int n_col_blocks
cs_lnum_tcol_block_sizes
cs_lnum_tmax_col_block_sizes
cs_lnum_t full_rhs_size
cs_real_trhs
cs_real_t_rhs
cs_real_t ** rhs_array
int n_blocks
cs_cdo_system_block_t ** blocks
Structure to handle linear systems which may be simply described by one block and one matrix or can be defined by a set of different blocks in more complex situations. The layout of the matrix is detailed thanks to block of different nature. The rhs can be also defined by block or thanks to a full-length array.
Field Documentation
◆ _rhs
cs_real_t* _rhs
◆ blocks
blocks
array of pointers to block structures
◆ col_block_sizes
col_block_sizes
size of each block (size = n_elts * stride). This size corresponds to the number of DoFs in a "scattered" view
◆ full_rhs_size
full_rhs_size
size of the rhs when taking into account all column blocks
◆ max_col_block_sizes
max_col_block_sizes
max. size of each block. This size takes into account DoFs shared across ranks. In a sequential run, the values in the max_col_block_sizes array should be equal to the values in the col_block_sizes array.
◆ n_blocks
n_blocks
number of blocks used to describe the system layout
◆ n_col_blocks
n_col_blocks
number of blocks in a row
◆ rhs
rhs
If allocated, it means that the system has its own rhs which is allocated in one array of the maximal size
◆ rhs_array
rhs_array
rhs array which is split in as many parts as there are blocks in a row (size n_col_blocks)
◆ type
type
type of system. The type predefines some behaviors.
