7.1
Electric arcs Joule examples
Local variables to be added
const cs_mesh_t *m = cs_glob_mesh;
const cs_lnum_t *b_face_cells = cs_glob_mesh->b_face_cells;
const cs_lnum_t n_b_faces = cs_glob_mesh->n_b_faces;
const cs_real_3_t *b_face_normal
const int keyvar = cs_field_key_id("variable_id");
int nbelec = cs_glob_transformer->nbelec;
int nbtrf = cs_glob_transformer->nbtrf;
cs_real_t *sir, *sii, *sirt, *siit;
cs_real_6_t *sirb, *siib, *ur, *ui;
int *nborne;
char name[8];
BFT_MALLOC(sir, nbelec, cs_real_t);
BFT_MALLOC(sii, nbelec, cs_real_t);
BFT_MALLOC(sirt, nbtrf, cs_real_t);
BFT_MALLOC(siit, nbtrf, cs_real_t);
BFT_MALLOC(siib, nbtrf, cs_real_6_t);
BFT_MALLOC(sirb, nbtrf, cs_real_6_t);
BFT_MALLOC(ui, nbtrf, cs_real_6_t);
BFT_MALLOC(ur, nbtrf, cs_real_6_t);
BFT_MALLOC(nborne, nbtrf, int);
Computation of intensity (A/m2) for each electrode
Pre initialisation
for (int i = 0; i < nbelec; i++) {
sir[i] = 0.;
sii[i] = 0.;
for (int i = 0; i < nbtrf; i++) {
sirt[i] = 0.;
siit[i] = 0.;
nborne[i] = 0;
transfo->uroff[i] = 0.;
transfo->uioff[i] = 0.;
cs_lnum_t nelts;
cs_lnum_t *lstelt = NULL;
sprintf(name, "%07d", transfo->ielecc[i]);
cs_selector_get_b_face_list(name, &nelts, lstelt);
cs_real_3_t *cpro_curre = (cs_real_3_t *)(CS_F_(curre)->val);
cs_real_3_t *cpro_curim = NULL;
if (ieljou == 4)
cpro_curim = (cs_real_3_t *)(CS_F_(curim)->val);
for (cs_lnum_t ilelt = 0; ilelt < nelts; ilelt++) {
cs_lnum_t face_id = lstelt[ilelt];
cs_lnum_t cell_id = b_face_cells[face_id];
for (cs_lnum_t id = 0; id < 3; id++)
sir[i] += cpro_curre[cell_id][id] * b_face_normal[id][face_id];
if (ieljou == 4)
sii[i] += cpro_curim[cell_id][id] * b_face_normal[id][face_id];
BFT_FREE(lstelt);
Definition of Voltage on each termin of transformers
Computation of Intensity on each termin of transformers:
sirb[transfo->ielect[i]][transfo->ielecb[i]] = 0.;
if (ieljou == 4)
siib[transfo->ielect[i]][transfo->ielecb[i]] = 0.;
if (transfo->ielect[i] != 0) {
sirb[transfo->ielect[i]][transfo->ielecb[i]] += sir[i];
if (ieljou == 4)
siib[transfo->ielect[i]][transfo->ielecb[i]] += sii[i];
RVoltage on each termin:
for (int ntf = 0; ntf < nbtrf; ntf++) {
/* Primary and Secondary in Triangle */
if (transfo->ibrpr[ntf] == 0 &&
transfo->ibrsec[ntf] == 0) {
nborne[ntf] = 3;
double rnbs2 = 3. * transfo->rnbs[ntf]
* transfo->rnbs[ntf];
ur[ntf][0] = 1.154675 * transfo->tenspr[ntf]
/ transfo->rnbs[ntf]
+ (transfo->zr[ntf] * sirb[ntf][0]
- transfo->zi[ntf] * siib[ntf][0]) / rnbs2;
ur[ntf][1] = -0.5773 * transfo->tenspr[ntf]
+ (transfo->zr[ntf] * sirb[ntf][1]
- transfo->zi[ntf] * siib[ntf][1]) / rnbs2;
ur[ntf][2] =-0.5773 * transfo->tenspr[ntf]
+ (transfo->zr[ntf] * sirb[ntf][2]
- transfo->zi[ntf] * siib[ntf][2]) / rnbs2;
ui[ntf][0] = (transfo->zi[ntf] * sirb[ntf][0]
- transfo->zr[ntf] * siib[ntf][0]) / rnbs2;
ui[ntf][1] = (transfo->zi[ntf] * sirb[ntf][1]
- transfo->zr[ntf] * siib[ntf][1]) / rnbs2;
ui[ntf][2] = (transfo->zi[ntf] * sirb[ntf][2]
- transfo->zr[ntf] * siib[ntf][2]) / rnbs2;
else
bft_error(__FILE__, __LINE__, 0,
_("electric module : \n"
"transformer matrix not defined\n"));
Total intensity for a transformer (zero valued WHEN Offset established):
sirt[ntf] = 0.;
if (ieljou == 4)
siit[ntf] = 0.;
sirt[i] += sir[i];
if (ieljou == 4)
siit[i] += sii[i];
Take in account of Offset:
double capaeq = 3.;
transfo->uroff[ntf] += sirt[ntf] / capaeq;
if (ieljou == 4)
transfo->uioff[ntf] += siit[ntf] / capaeq;
/* A reference transformer is assumed to have an Offset zero valued */
if (transfo->ntfref > 0) {
transfo->uroff[transfo->ntfref] = 0.;
transfo->uioff[transfo->ntfref] = 0.;
for (int nb = 0; nb < nborne[ntf]; nb++) {
ur[ntf][nb] += transfo->uroff[ntf];
if (ieljou == 4)
ui[ntf][nb] += transfo->uioff[ntf];
/* Print of UROFF (real part of offset potential) */
bft_printf(" ** INFORMATIONS ON TRANSFOMERS\n");
bft_printf(" ---------------------------------------\n");
bft_printf(" ---------------------------------\n");
bft_printf(" Number of Transfo UROFF\n");
bft_printf(" %6i %12.5E\n", ntf, transfo->uroff[ntf]);
Take in account of Boundary Conditions
cs_lnum_t nelts;
bc_type[face_id] = CS_SMOOTHWALL;
const cs_field_t *f = CS_F_(potr);
int ivar = cs_field_get_key_int(f, keyvar) - 1;
icodcl[ivar * n_b_faces + face_id] = 1;
rcodcl[ivar * n_b_faces + face_id] = ur[transfo->ielect[i]][transfo->ielecb[i]];
if (ieljou == 4) {
f = CS_F_(poti);
else {
icodcl[ivar * n_b_faces + face_id] = 3;
rcodcl[2 * n_b_faces * nvar + ivar * n_b_faces + face_id] = 0.;
if (ieljou == 4) {
f = CS_F_(poti);
BFT_FREE(lstelt);
/* Test, if not any reference transformer
* a piece of wall may be at ground. */
if (transfo->ntfref == 0) {
bool found = false;
for (cs_lnum_t face_id = 0; face_id < n_b_faces; face_id++) {
if (bc_type[face_id] == CS_SMOOTHWALL) {
if (icodcl[ivar * n_b_faces + face_id] == 1) {
if (ieljou == 3) {
if (fabs(rcodcl[ivar * n_b_faces + face_id]) < 1.e-20)
found = true;
else if (ieljou == 4) {
double val = fabs(rcodcl[ivar * n_b_faces + face_id]);
f = CS_F_(poti);
if (fabs(rcodcl[ivar * n_b_faces + face_id]) < 1.e-20 &&
val < 1.e-20)
found = true;
if (!found)
_("ERROR in JOULE : \n"
"Lack of reference : choose a transformer for wich\n"
"offset is assumed zero or a face at ground on the\n"
"boundary\n"));
Finalization step
Test, if not any reference transformer a piece of wall may be at ground:
BFT_FREE(sir);
BFT_FREE(sii);
BFT_FREE(sirb);
BFT_FREE(siib);
BFT_FREE(ur);
BFT_FREE(ui);
BFT_FREE(sirt);
BFT_FREE(siit);
BFT_FREE(nborne);
