| void | elini1 (cs_real_t *diftl0) |
| void | elflux (int *iappel) |
| void | elthht (int *mode, cs_real_t *ym, cs_real_t *enthal, cs_real_t *temp) |
| void | ellecd (void) |
| void | elphyv (void) |
| void | eltssc (const int *isca, cs_real_t *smbrs) |
| void | eltsvv (const int *f_id, cs_real_t *smbrv) |
| void | eliniv (int *isuite) |
| void | elreca (cs_real_t *dt) |
| cs_elec_option_t * | cs_get_glob_elec_option (void) |
| cs_data_joule_effect_t * | cs_get_glob_transformer (void) |
| void | cs_electrical_model_initialize (void) |
| void | cs_electrical_model_finalize (void) |
| void | cs_electrical_model_specific_initialization (cs_real_t *diftl0) |
| void | cs_electrical_properties_read (void) |
| void | cs_elec_compute_fields (const cs_mesh_t *mesh, int call_id) |
| void | cs_elec_physical_properties (cs_domain_t *domain) |
| void | cs_elec_source_terms (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, int f_id, cs_real_t *smbrs) |
| void | cs_elec_source_terms_v (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, int f_id, cs_real_3_t *smbrv) |
| void | cs_elec_add_variable_fields (void) |
| void | cs_elec_add_property_fields (void) |
| void | cs_elec_fields_initialize (const cs_mesh_t *mesh, int isuite) |
| void | cs_elec_scaling_function (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, cs_real_t *dt) |
| void | cs_elec_convert_h_to_t_faces (const cs_real_t h[], cs_real_t t[]) |
| | Convert enthalpy to temperature at all boundary faces. More...
| void | cs_elec_convert_t_to_h_cells (const cs_real_t t[], cs_real_t h[]) |
| | Convert temperature to enthalpy at all cells. More...
| void | cs_elec_convert_t_to_h_faces (const cs_lnum_t n_faces, const cs_lnum_t face_ids[], const cs_real_t t[], cs_real_t h[]) |
| | Convert temperature to enthalpy at selected boundary faces. More...
◆ cs_elec_add_property_fields()
| void cs_elec_add_property_fields |
void |
◆ cs_elec_add_variable_fields()
| void cs_elec_add_variable_fields |
void |
◆ cs_elec_compute_fields()
| void cs_elec_compute_fields |
const cs_mesh_t * |
mesh, |
int |
call_id |
◆ cs_elec_convert_h_to_t_faces()
This handles both user and model enthalpy conversions, so can be used safely whenever conversion is needed.
- Parameters
| [in] | h | enthalpy values |
| [out] | t | temperature values |
◆ cs_elec_convert_t_to_h_cells()
This handles both user and model temperature conversions, so can be used safely whenever conversion is needed.
- Parameters
| [in] | t | temperature values |
| [out] | h | enthalpy values |
◆ cs_elec_convert_t_to_h_faces()
- Parameters
| [in] | n_faces | number of selected faces |
| [in] | face_ids | ids of selected faces |
| [in] | t | temperature values (defined on all boundary faces) |
| [out] | h | enthalpy values (defined on all boundary faces) |
◆ cs_elec_fields_initialize()
| void cs_elec_fields_initialize |
const cs_mesh_t * |
mesh, |
int |
isuite |
◆ cs_elec_physical_properties()
| void cs_elec_physical_properties |
cs_domain_t * |
domain | ) |
◆ cs_elec_scaling_function()
◆ cs_elec_source_terms()
◆ cs_elec_source_terms_v()
◆ cs_electrical_model_finalize()
| void cs_electrical_model_finalize |
void |
◆ cs_electrical_model_initialize()
| void cs_electrical_model_initialize |
void |
◆ cs_electrical_model_specific_initialization()
| void cs_electrical_model_specific_initialization |
cs_real_t * |
diftl0 | ) |
◆ cs_electrical_properties_read()
| void cs_electrical_properties_read |
void |
◆ cs_get_glob_elec_option()
◆ cs_get_glob_transformer()
◆ elflux()
| void elflux |
int * |
iappel | ) |
◆ elini1()
◆ eliniv()
| void eliniv |
int * |
isuite | ) |
◆ ellecd()
◆ elphyv()
◆ elreca()
◆ elthht()
◆ eltssc()
| void eltssc |
const int * |
isca, |
cs_real_t * |
smbrs |
◆ eltsvv()
| void eltsvv |
const int * |
f_id, |
cs_real_t * |
smbrv |
◆ cs_elec_epszer
vacuum permittivity constant (F/m). (= 8.854e-12)
◆ cs_elec_permvi
vacuum magnetic permeability constant (H/m). (= 1.2566e-6)
◆ cs_glob_elec_option
◆ cs_glob_elec_properties
◆ cs_glob_transformer
