Functions to handle the cs_thermal_system_t structure. This module can be used stand alone or linked with another module such as Navier-Stokes, groundwater flows or Maxwell... The temperature field is automatically defined when this module is activated. More...
#include "cs_advection_field.h"#include "cs_equation.h"#include "cs_field.h"#include "cs_property.h"#include "cs_mesh.h"#include "cs_source_term.h"#include "cs_time_step.h"#include "cs_xdef.h"
Include dependency graph for cs_thermal_system.h:Go to the source code of this file.
| struct | cs_thermal_system_t |
Macros | |
| #define | CS_THERMAL_EQNAME "thermal_equation" |
| #define | CS_THERMAL_CP_NAME "thermal_capacity" |
| #define | CS_THERMAL_LAMBDA_NAME "thermal_conductivity" |
Flags specifying automatic post-processing for the thermal module | |
| #define | CS_THERMAL_POST_ENTHALPY (1 << 0) /* 1 */ |
| Create a field storing the enthalpy for post-processing and extra-operation. More... | |
| typedef cs_flag_t | cs_thermal_model_type_t |
Enumerations | |
| enum | cs_thermal_model_type_bit_t { CS_THERMAL_MODEL_STEADY = 1<<0, CS_THERMAL_MODEL_NAVSTO_ADVECTION = 1<<1, CS_THERMAL_MODEL_USE_TEMPERATURE = 1<<2, CS_THERMAL_MODEL_USE_ENTHALPY = 1<<3, CS_THERMAL_MODEL_USE_TOTAL_ENERGY = 1<<4, CS_THERMAL_MODEL_ANISOTROPIC_CONDUCTIVITY = 1<<5, CS_THERMAL_MODEL_IN_CELSIUS = 1<<7 } |
| Bit values for physical modelling related to thermal system. More... | |
| cs_real_t | cs_thermal_system_get_reference_temperature (void) |
| Retrieve the value of the reference temperature associated to a thermal system. More... | |
| void | cs_thermal_system_set_reference_temperature (cs_real_t ref) |
| Set the value of the reference temperature associated to the thermal system. More... | |
| cs_flag_t | cs_thermal_system_get_model (void) |
| Retrieve the model flag related to a thermal system. More... | |
| bool | cs_thermal_system_needs_navsto (void) |
| Does the thermal system rely on the advection field associated to the Navier-Stokes equations ? More... | |
| bool | cs_thermal_system_is_activated (void) |
| Check if the resolution of the thermal system has been activated. More... | |
| cs_thermal_system_t * | cs_thermal_system_activate (cs_flag_t model, cs_flag_t numeric, cs_flag_t post) |
| Allocate and initialize the thermal system. More... | |
| void | cs_thermal_system_destroy (void) |
| Free the main structure related to the thermal system. More... | |
| cs_equation_t * | cs_thermal_system_get_equation (void) |
| Retrieve the main equation related to the thermal system. More... | |
| cs_real_t * | cs_thermal_system_get_face_temperature (void) |
| Retrieve the current temperature at face values. More... | |
| void | cs_thermal_system_init_setup (void) |
| Start setting-up the thermal system At this stage, numerical settings should be completely determined but connectivity and geometrical information is not yet available. More... | |
| void | cs_thermal_system_finalize_setup (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step) |
| Last step of the setup of the thermal system. More... | |
| void | cs_thermal_system_compute_steady_state (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step) |
| Build and solve a steady-state thermal system. More... | |
| void | cs_thermal_system_compute (bool cur2prev, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step) |
| Build and solve the thermal system. More... | |
| void | cs_thermal_system_update (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *ts, bool cur2prev) |
| Update/initialize the thermal module according to the settings. More... | |
| void | cs_thermal_system_extra_op (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq) |
| Predefined extra-operations for the thermal system. More... | |
| void | cs_thermal_system_extra_post (void *input, int mesh_id, int cat_id, int ent_flag[5], cs_lnum_t n_cells, cs_lnum_t n_i_faces, cs_lnum_t n_b_faces, const cs_lnum_t cell_ids[], const cs_lnum_t i_face_ids[], const cs_lnum_t b_face_ids[], const cs_time_step_t *time_step) |
| Predefined post-processing output for the thermal system. The prototype of this function is fixed since it is a function pointer defined in cs_post.h (cs_post_time_mesh_dep_output_t) More... | |
| void | cs_thermal_system_log_setup (void) |
| Summary of the main options related to cs_thermal_system_t structure. More... | |
Moreover, one considers according to the modelling rho the volumetric mass (mass density) Cp the heat capacity lambda the heat conductivity
| #define CS_THERMAL_CP_NAME "thermal_capacity" |
| #define CS_THERMAL_EQNAME "thermal_equation" |
| #define CS_THERMAL_LAMBDA_NAME "thermal_conductivity" |
| #define CS_THERMAL_POST_ENTHALPY (1 << 0) /* 1 */ |
| typedef cs_flag_t cs_thermal_model_type_t |
| cs_thermal_system_t* cs_thermal_system_activate | ( | cs_thermal_model_type_t | model, |
| cs_flag_t | numeric, | ||
| cs_flag_t | post | ||
| [in] | model | model flag related to the thermal system |
| [in] | numeric | (optional) numerical flag settings |
| [in] | post | (optional) post-processing flag settings |
| void cs_thermal_system_compute | ( | bool | cur2prev, |
| void cs_thermal_system_compute_steady_state | ( | const cs_mesh_t * | mesh, |
| void cs_thermal_system_destroy | ( | void | ) |
| void cs_thermal_system_extra_op | ( | const cs_cdo_connect_t * | connect, |
| void cs_thermal_system_extra_post | ( | void * | input, |
| int | mesh_id, | ||
| int | cat_id, | ||
| int | ent_flag[5], | ||
| cs_lnum_t | n_cells, | ||
| cs_lnum_t | n_i_faces, | ||
| cs_lnum_t | n_b_faces, | ||
| [in,out] | input | pointer to a optional structure (here a cs_thermal_system_t structure) |
| void cs_thermal_system_finalize_setup | ( | const cs_cdo_connect_t * | connect, |
| cs_equation_t* cs_thermal_system_get_equation | ( | void | ) |
| cs_real_t* cs_thermal_system_get_face_temperature | ( | void | ) |
| cs_flag_t cs_thermal_system_get_model | ( | void | ) |
| cs_real_t cs_thermal_system_get_reference_temperature | ( | void | ) |
| void cs_thermal_system_init_setup | ( | void | ) |
| bool cs_thermal_system_is_activated | ( | void | ) |
| void cs_thermal_system_log_setup | ( | void | ) |
| bool cs_thermal_system_needs_navsto | ( | void | ) |
| void cs_thermal_system_set_reference_temperature | ( | cs_real_t | ref | ) |
| [in] | ref | value of the reference temperature |
| void cs_thermal_system_update | ( | const cs_mesh_t * | mesh, |
| bool | cur2prev | ||
