#include "cs_matrix.h"
#include "cs_sles.h"
| enum | cs_sles_hypre_type_t {
CS_SLES_HYPRE_BOOMERAMG,
CS_SLES_HYPRE_HYBRID,
CS_SLES_HYPRE_ILU,
CS_SLES_HYPRE_BICGSTAB,
CS_SLES_HYPRE_GMRES,
CS_SLES_HYPRE_FLEXGMRES,
CS_SLES_HYPRE_LGMRES,
CS_SLES_HYPRE_PCG,
CS_SLES_HYPRE_EUCLID,
CS_SLES_HYPRE_PARASAILS,
CS_SLES_HYPRE_NONE
| cs_sles_hypre_t * | cs_sles_hypre_define (int f_id, const char *name, cs_sles_hypre_type_t solver_type, cs_sles_hypre_type_t precond_type, cs_sles_hypre_setup_hook_t *setup_hook, void *context) |
| | Define and associate a HYPRE linear system solver for a given field or equation name. More...
| cs_sles_hypre_t * | cs_sles_hypre_create (cs_sles_hypre_type_t solver_type, cs_sles_hypre_type_t precond_type, cs_sles_hypre_setup_hook_t *setup_hook, void *context) |
| | Create HYPRE linear system solver info and context. More...
| void | cs_sles_hypre_destroy (void **context) |
| void * | cs_sles_hypre_copy (const void *context) |
| void | cs_sles_hypre_setup (void *context, const char *name, const cs_matrix_t *a, int verbosity) |
| cs_sles_convergence_state_t | cs_sles_hypre_solve (void *context, const char *name, const cs_matrix_t *a, int verbosity, double precision, double r_norm, int *n_iter, double *residue, const cs_real_t *rhs, cs_real_t *vx, size_t aux_size, void *aux_vectors) |
| void | cs_sles_hypre_free (void *context) |
| bool | cs_sles_hypre_error_post_and_abort (cs_sles_t *sles, cs_sles_convergence_state_t state, const cs_matrix_t *a, const cs_real_t *rhs, cs_real_t *vx) |
| | Error handler for HYPRE solver. More...
| void | cs_sles_hypre_log (const void *context, cs_log_t log_type) |
| void | cs_sles_hypre_set_host_device (cs_sles_hypre_t *context, int use_device) |
| | Define whether the solver should run on the host or accelerated device. More...
| int | cs_sles_hypre_get_host_device (const cs_sles_hypre_t *context) |
| | Query whether the solver should run on the host or accelerated device. More...
| void | cs_sles_hypre_library_info (cs_log_t log_type) |
| | Print information on hypre library. More...
◆ cs_sles_hypre_setup_hook_t
| cs_sles_hypre_setup_hook_t |
Function pointer for settings of a HYPRE solver setup.
This function is called during the setup stage for a HYPRE solver.
When first called, the solver argument is NULL, and must be created using HYPRE functions.
Note: if the context pointer is non-NULL, it must point to valid data when the selection function is called so that value or structure should not be temporary (i.e. local);
- Parameters
| [in,out] | context | pointer to optional (untyped) value or structure |
| [in,out] | solver | handle to HYPRE solver (to be cast as HYPRE_Solver) |
◆ cs_sles_hypre_t
◆ cs_sles_hypre_type_t
| Enumerator |
| CS_SLES_HYPRE_BOOMERAMG | BoomerAMG (algebraic multigrid)
| CS_SLES_HYPRE_HYBRID | Hybrid solver
| CS_SLES_HYPRE_ILU | hypre-ILU (incomplete LU)
| CS_SLES_HYPRE_BICGSTAB | BiCGSTAB
| CS_SLES_HYPRE_GMRES | GMRES
| CS_SLES_HYPRE_FLEXGMRES | Flexible GMRES
| CS_SLES_HYPRE_LGMRES | LGMRES
| CS_SLES_HYPRE_PCG | Preconditioned Congugate Gradient
| CS_SLES_HYPRE_EUCLID | hypre-ILU (incomplete LU)
| CS_SLES_HYPRE_PARASAILS | ParaSails (sparse approximate inverse))
| CS_SLES_HYPRE_NONE | No solver or preconditioner
◆ cs_sles_hypre_copy()
| void* cs_sles_hypre_copy |
const void * |
context | ) |
◆ cs_sles_hypre_create()
- Parameters
| [in] | solver_type | HYPRE solver type |
| [in] | precond_type | HYPRE preconditioner type |
| [in] | setup_hook | pointer to optional setup epilogue function |
| [in] | context | pointer to optional (untyped) value or structure for setup_hook, or NULL |
- Returns
- pointer to newly created linear system object.
◆ cs_sles_hypre_define()
This is a utility function: if finer control is needed, see cs_sles_define and cs_sles_petsc_create.
The associated solver required that the matrix passed to it is a HYPRE matrix (see cs_matrix_set_type_hypre).
Note that this function returns a pointer directly to the iterative solver management structure. This may be used to set further options. If needed, cs_sles_find may be used to obtain a pointer to the matching cs_sles_t container.
- Parameters
| [in,out] | context | pointer to optional (untyped) value or structure for setup_hook, or NULL |
- Returns
- pointer to newly created iterative solver info object.
◆ cs_sles_hypre_destroy()
| void cs_sles_hypre_destroy |
void ** |
context | ) |
◆ cs_sles_hypre_error_post_and_abort()
In case of divergence or breakdown, this error handler outputs an error message It does nothing in case the maximum iteration count is reached.
- Parameters
| [in] | a | matrix |
- Returns
- false (do not attempt new solve)
◆ cs_sles_hypre_free()
| void cs_sles_hypre_free |
void * |
context | ) |
◆ cs_sles_hypre_get_host_device()
- Parameters
| [in,out] | context | pointer to HYPRE linear solver info |
- Returns
- 0 for host, 1 for device (GPU)
◆ cs_sles_hypre_library_info()
| void cs_sles_hypre_library_info |
cs_log_t |
log_type | ) |
- Parameters
◆ cs_sles_hypre_log()
| void cs_sles_hypre_log |
const void * |
context, |
cs_log_t |
log_type |
◆ cs_sles_hypre_set_host_device()
| void cs_sles_hypre_set_host_device |
cs_sles_hypre_t * |
context, |
int |
use_device |
If no device is available, this setting is ignored.
- Parameters
| [in] | use_device | 0 for host, 1 for device (GPU) |
◆ cs_sles_hypre_setup()
| void cs_sles_hypre_setup |
void * |
context, |
const char * |
name, |
const cs_matrix_t * |
a, |
int |
verbosity |
◆ cs_sles_hypre_solve()
| cs_sles_convergence_state_t cs_sles_hypre_solve |
void * |
context, |
const char * |
name, |
a, |
int |
verbosity, |
double |
precision, |
double |
r_norm, |
int * |
n_iter, |
double * |
residue, |
const cs_real_t * |
rhs, |
cs_real_t * |
vx, |
size_t |
aux_size, |
void * |
aux_vectors |
