#include "cs_restart.h"
◆ cs_restart_map_build()
void cs_restart_map_build |
void |
Build mapping of restart files to different mesh if defined.
◆ cs_restart_map_free()
void cs_restart_map_free |
void |
Free restart file mapping to different mesh.
Revert restart reading to default behavior.
◆ cs_restart_map_set_mesh_input()
void cs_restart_map_set_mesh_input |
const char * |
mesh_path | ) |
Indicate restart files should be mapped to a given mesh input.
- Parameters
[in] | mesh_path | path to mesh input |
◆ cs_restart_map_set_options()
void cs_restart_map_set_options |
float |
tolerance_base, |
float |
tolerance_fraction |
Set options relative to restart file mapping to a given mesh input.
- Parameters
[in] | tolerance_base | associated base tolerance (used for bounding box check only, not for location test) |
[in] | tolerance_fraction | associated fraction of element bounding boxes added to tolerance |
