7.1
cs_restart_map.h
1 #ifndef __CS_RESTART_MAP_H__
2 #define __CS_RESTART_MAP_H__
5  * Checkpoint / restart extension to mapped meshes
35  * Local headers
38 #include "cs_defs.h"
39 #include "cs_restart.h"
46  * Macro definitions
48
49
51  * Local type definitions
53
54
56  * Global variables
58
59
60 /*============================================================================
61  * Public function prototypes
62  *============================================================================*/
63
64 /*----------------------------------------------------------------------------*/
70 /*----------------------------------------------------------------------------*/
71
72 void
73 cs_restart_map_set_mesh_input(const char *mesh_path);
74
75 /*----------------------------------------------------------------------------*/
84 /*----------------------------------------------------------------------------*/
85
86 void
87 cs_restart_map_set_options(float tolerance_base,
88  float tolerance_fraction);
89
94 /*----------------------------------------------------------------------------*/
95
96 void
98
99 /*----------------------------------------------------------------------------*/
105 /*----------------------------------------------------------------------------*/
106
107 void
108 cs_restart_map_free(void);
109
110 /*----------------------------------------------------------------------------*/
111
113
114 #endif /* __CS_RESTART_MAP_H__ */
void cs_restart_map_free(void)
Free restart file mapping to different mesh.
Definition: cs_restart_map.c:447
void cs_restart_map_build(void)
Build mapping of restart files to different mesh if defined.
Definition: cs_restart_map.c:318
void cs_restart_map_set_mesh_input(const char *mesh_path)
Indicate restart files should be mapped to a given mesh input.
Definition: cs_restart_map.c:283
void cs_restart_map_set_options(float tolerance_base, float tolerance_fraction)
Set options relative to restart file mapping to a given mesh input.
Definition: cs_restart_map.c:304
