#include "fvm_periodicity.h"
#include "cs_block_dist.h"
#include "cs_interface.h"
struct | cs_mesh_builder_t |
cs_mesh_builder_t * | cs_mesh_builder_create (void) |
Create an empty mesh builder structure. More... | |
void | cs_mesh_builder_destroy (cs_mesh_builder_t **mb) |
Destroy a cs_mesh_builder_t structure. More... | |
void | cs_mesh_builder_define_block_dist (cs_mesh_builder_t *mb, int rank_id, int n_ranks, int min_rank_step, int min_block_size, cs_gnum_t n_g_cells, cs_gnum_t n_g_faces, cs_gnum_t n_g_vertices) |
Define block distribution sizes for mesh builder. More... | |
cs_mesh_builder_t * | cs_glob_mesh_builder |
cs_mesh_builder_t* cs_mesh_builder_create | ( | void | ) |
void cs_mesh_builder_define_block_dist | ( | cs_mesh_builder_t * | mb, |
int | rank_id, | ||
int | n_ranks, | ||
int | min_rank_step, | ||
int | min_block_size, | ||
cs_gnum_t | n_g_cells, | ||
cs_gnum_t | n_g_faces, | ||
cs_gnum_t | n_g_vertices | ||
[in,out] | mb | pointer to mesh builder to update |
[in] | rank_id | id of local rank |
[in] | n_ranks | number of associated ranks |
[in] | min_rank_step | minimum rank step between blocks |
[in] | min_block_size | minimum number of entities per block |
[in] | n_g_cells | global number of cells |
[in] | n_g_faces | global number of faces |
[in] | n_g_vertices | global number of vertices |
void cs_mesh_builder_destroy | ( | cs_mesh_builder_t ** | mb | ) |
[in,out] | mb | pointer to pointer of structure to destroy |
cs_mesh_builder_t* cs_glob_mesh_builder |
