7.1
cs_fan.h File Reference
+ Include dependency graph for cs_fan.h:
Typedefs
typedef struct _cs_fan_t cs_fan_t
void debvtl (cs_real_t flumas[], cs_real_t flumab[], cs_real_t rhofac[], cs_real_t rhofab[])
void tsvvtl (cs_real_3_t crvexp[])
void cs_fan_define (int fan_dim, int mode, const cs_real_t inlet_axis_coords[3], const cs_real_t outlet_axis_coords[3], cs_real_t fan_radius, cs_real_t blades_radius, cs_real_t hub_radius, const cs_real_t curve_coeffs[3], cs_real_t axial_torque)
 Fan definition (added to the ones previously defined) More...
void cs_fan_destroy_all (void)
 Destroy the structures associated with fans. More...
int cs_fan_n_fans (void)
 Return number of fans. More...
void cs_fan_log_setup (void)
 Log fans definition setup information. More...
void cs_fan_log_iteration (void)
 Log fan information for a given iteration. More...
void cs_fan_build_all (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities)
 Define the cells belonging to the different fans. More...
void cs_fan_compute_flows (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, const cs_real_t i_mass_flux[], const cs_real_t b_mass_flux[], const cs_real_t c_rho[], const cs_real_t b_rho[])
 Compute the flows through the fans. More...
void cs_fan_compute_force (const cs_mesh_quantities_t *mesh_quantities, cs_real_3_t source_t[])
 Compute the force induced by the fans (needs a previous calculation of the flows through each fan). More...
void cs_fan_flag_cells (const cs_mesh_t *mesh, int cell_fan_id[])
 Flag the cells belonging to the different fans (by the fan id, -1 otherwise) More...
void cs_fan_cells_select (void *input, cs_lnum_t *n_cells, cs_lnum_t **cell_ids)
 Selection function for cells belonging to fans. More...
Typedef Documentation
◆ cs_fan_t
◆ cs_fan_build_all()
void cs_fan_build_all ( const cs_mesh_t mesh,
const cs_mesh_quantities_t mesh_quantities
[in]meshassociated mesh structure
[in]mesh_quantitiesmesh quantities
◆ cs_fan_cells_select()
void cs_fan_cells_select ( void *  input,
cs_lnum_t n_cells,
cs_lnum_t **  cell_ids
This function may be used for the definition of postprocessing meshes.
[in,out]inputpointer to input (unused here)
[out]n_cellsnumber of selected cells
[out]cell_idsarray of selected cell ids (0 to n-1 numbering)
◆ cs_fan_compute_flows()
void cs_fan_compute_flows ( const cs_mesh_t mesh,
const cs_mesh_quantities_t mesh_quantities,
[in]meshmesh structure
[in]i_mass_fluxinterior faces mass flux
[in]b_mass_fluxboundary faces mass flux
[in]c_rhodensity at cells
[in]b_rhodensity at boundary faces
◆ cs_fan_compute_force()
void cs_fan_compute_force ( const cs_mesh_quantities_t mesh_quantities,
[in]source_texplicit source term for the velocity
◆ cs_fan_define()
void cs_fan_define ( int  fan_dim,
int  mode,
Fans are handled as explicit momentum source terms at the given location, based on the fan's axis and diameter. The fan's pressure characteristic curve is defined by 3 coefficients, such that: $\delta P = C_0 + C_1.flow + C_2.flow^2$. An axial torque may also be defined for the 3D model.
[in]fan_dimfan dimension: 2: pseudo-2D (extruded mesh) 3: 3D (standard)
[in]modemode: 0: fan 1: wind turbine
[in]inlet_axis_coordsintersection of axis and inlet face
[in]outlet_axis_coordsintersection of axis and outlet face
[in]fan_radiusfan radius
[in]blades_radiusblades radius
[in]hub_radiushub radius
[in]curve_coeffscoefficients of degre 0, 1 and 2 of the pressure drop/flow rate characteristic curve
[in]axial_torquefan axial torque
◆ cs_fan_destroy_all()
void cs_fan_destroy_all ( void  )
◆ cs_fan_flag_cells()
void cs_fan_flag_cells ( const cs_mesh_t mesh,
int  cell_fan_id[]
[in]meshassosiated mesh structure
[out]cell_fan_idfan id (or -1) for each cell
◆ cs_fan_log_iteration()
void cs_fan_log_iteration ( void  )
◆ cs_fan_log_setup()
void cs_fan_log_setup ( void  )
◆ cs_fan_n_fans()
int cs_fan_n_fans ( void  )
number of defined fans
◆ debvtl()
void debvtl ( cs_real_t  flumas[],
cs_real_t  flumab[],
cs_real_t  rhofac[],
cs_real_t  rhofab[]
◆ tsvvtl()
void tsvvtl ( cs_real_3_t  crvexp[])
