7.1
cs_domain_setup.h File Reference
#include "cs_advection_field.h"
#include "cs_domain.h"
#include "cs_equation.h"
#include "cs_gwf.h"
#include "cs_param_types.h"
#include "cs_property.h"
+ Include dependency graph for cs_domain_setup.h:
void cs_domain_set_output_param (cs_domain_t *domain, int nt_interval, int nt_list, int verbosity)
 Set to true the automatic update of all advection fields. More...
void cs_domain_set_time_param (cs_domain_t *domain, int nt_max, double t_max)
 Set parameters for unsteady computations: the max number of time steps or the final physical time of the simulation. More...
void cs_domain_automatic_time_step_settings (cs_domain_t *domain)
 Set time step parameters for unsteady computations when this is not already done. This situation should occur when the GUI is used to set a constant time step. More...
cs_xdef_tcs_domain_def_time_step_by_function (cs_domain_t *domain, cs_time_func_t *func, void *func_input)
 Define the value of the time step thanks to a predefined function. More...
void cs_domain_def_time_step_by_value (cs_domain_t *domain, double dt)
 Define the value of the time step. More...
void cs_domain_initialize_setup (cs_domain_t *domain)
 First setup stage of the cs_domain_t structure Define extra domain boundaries Setup predefined equations Create fields Define cs_sles_t structures for variable fields. More...
void cs_domain_init_cdo_structures (cs_domain_t *domain)
 After having read the mesh and the first setup stage build the connectivities and mesh quantities related to CDO/HHO schemes. More...
void cs_domain_finalize_user_setup (cs_domain_t *domain)
 Last user setup stage of the cs_domain_t structure. More...
void cs_domain_finalize_module_setup (cs_domain_t *domain)
 Last setup stage of the cs_domain_t structure. More...
void cs_domain_initialize_systems (cs_domain_t *domain)
 Initialize systems of equations and their related field values according to the user settings. More...
void cs_domain_setup_log (const cs_domain_t *domain)
 Summary of the main domain settings. More...
◆ cs_domain_automatic_time_step_settings()
void cs_domain_automatic_time_step_settings ( cs_domain_t domain)
◆ cs_domain_def_time_step_by_function()
cs_xdef_t* cs_domain_def_time_step_by_function ( cs_domain_t domain,
cs_time_func_t func,
void *  func_input
[in]funcpointer to a cs_time_func_t function
[in]func_inputpointer to a structure cast on-the-fly
a pointer to the created definition (cs_xdef_t structure)
◆ cs_domain_def_time_step_by_value()
void cs_domain_def_time_step_by_value ( cs_domain_t domain,
double  dt
[in]dtvalue of the constant time step
◆ cs_domain_finalize_module_setup()
void cs_domain_finalize_module_setup ( cs_domain_t domain)
[in,out]domainpointer to a cs_domain_t struct.
◆ cs_domain_finalize_user_setup()
void cs_domain_finalize_user_setup ( cs_domain_t domain)
◆ cs_domain_init_cdo_structures()
void cs_domain_init_cdo_structures ( cs_domain_t domain)
◆ cs_domain_initialize_setup()
void cs_domain_initialize_setup ( cs_domain_t domain)
◆ cs_domain_initialize_systems()
void cs_domain_initialize_systems ( cs_domain_t domain)
◆ cs_domain_set_output_param()
void cs_domain_set_output_param ( cs_domain_t domain,
int  nt_interval,
int  nt_list,
int  verbosity
Set auxiliary parameters related to the way output is done
[in]nt_intervalfrequency for the restart process
[in]nt_listoutput frequency into the log
[in]verbositylevel of information displayed
◆ cs_domain_set_time_param()
void cs_domain_set_time_param ( cs_domain_t domain,
int  nt_max,
double  t_max
[in]nt_maxmax. number of time step iterations
[in]t_maxfinal physical time of the simulation
◆ cs_domain_setup_log()
void cs_domain_setup_log ( const cs_domain_t domain)
[in]domainpointer to the cs_domain_t structure to summarize
