7.1
cs_cdofb_predco.h
1 #ifndef __CS_CDOFB_PREDCO_H__
2 #define __CS_CDOFB_PREDCO_H__
5  * Build an algebraic CDO face-based system for the Navier-Stokes equations
6  * and solved it with a prediction-correction algorithm
8
9 /*
10  This file is part of Code_Saturne, a general-purpose CFD tool.
11
12  Copyright (C) 1998-2021 EDF S.A.
13
17  version.
18
22  details.
23
27 */
28
30
31 #include "cs_defs.h"
32
33 /*----------------------------------------------------------------------------
34  * Standard C library headers
35  *----------------------------------------------------------------------------*/
36
37 /*----------------------------------------------------------------------------
38  * Local headers
39  *----------------------------------------------------------------------------*/
41 #include "cs_base.h"
42 #include "cs_cdo_connect.h"
43 #include "cs_cdo_quantities.h"
44 #include "cs_equation.h"
45 #include "cs_mesh.h"
46 #include "cs_navsto_coupling.h"
47 #include "cs_navsto_param.h"
48 #include "cs_source_term.h"
49 #include "cs_time_step.h"
50
51 /*----------------------------------------------------------------------------*/
52
54
55 /*============================================================================
56  * Macro definitions
58
59 /*============================================================================
60  * Type definitions
62
63 /*============================================================================
64  * Public function prototypes
65  *============================================================================*/
66
67 /*----------------------------------------------------------------------------*/
75 /*----------------------------------------------------------------------------*/
76
77 cs_real_t *
79
88 /*----------------------------------------------------------------------------*/
89
90 void
92  const cs_cdo_connect_t *connect,
93  const cs_time_step_t *time_step);
94
95 /*----------------------------------------------------------------------------*/
108 /*----------------------------------------------------------------------------*/
109
110 void *
112  cs_adv_field_t *adv_field,
113  cs_real_t *mflux,
114  cs_real_t *mflux_pre,
115  cs_boundary_type_t *fb_type,
116  void *nsc_input);
117
118 /*----------------------------------------------------------------------------*/
126 /*----------------------------------------------------------------------------*/
127
128 void *
129 cs_cdofb_predco_free_scheme_context(void *scheme_context);
130
131 /*----------------------------------------------------------------------------*/
140 /*----------------------------------------------------------------------------*/
141
142 void
144  void *context);
145
155 /*----------------------------------------------------------------------------*/
156
157 void
159  const cs_navsto_param_t *nsp,
160  void *scheme_context);
161
162 /*----------------------------------------------------------------------------*/
163
165
166 #endif /* __CS_CDOFB_PREDCO_H__ */
void cs_cdofb_predco_set_sles(const cs_navsto_param_t *nsp, void *context)
Start setting-up the Navier-Stokes equations when an AC algorithm is used to couple the system...
Definition: cs_cdofb_predco.c:986
time step descriptor
Definition: cs_time_step.h:64
int cs_boundary_type_t
Definition: cs_boundary.h:69
Definition: cs_advection_field.h:149
Definition: cs_navsto_param.h:605
Definition: cs_defs.h:322
Definition: cs_mesh.h:84
void cs_cdofb_predco_init_common(const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step)
Definition: cs_cdofb_predco.c:789
void * cs_cdofb_predco_free_scheme_context(void *scheme_context)
Destroy a cs_cdofb_predco_t structure.
Definition: cs_cdofb_predco.c:953
void cs_cdofb_predco_compute_implicit(const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context)
Solve the unsteady Navier-Stokes system with a CDO face-based scheme using a Artificial Compressibili...
Definition: cs_cdofb_predco.c:1058
void * cs_cdofb_predco_init_scheme_context(const cs_navsto_param_t *nsp, cs_adv_field_t *adv_field, cs_real_t *mflux, cs_real_t *mflux_pre, cs_boundary_type_t *fb_type, void *nsc_input)
Initialize a cs_cdofb_predco_t structure.
Definition: cs_cdofb_predco.c:825
cs_real_t * cs_cdofb_predco_get_face_pressure(void *context)
Retrieve the values of the pressure at faces.
Definition: cs_cdofb_predco.c:768
Definition: mesh.f90:26
