| #define | CS_MALLOC_HD(_ptr, _ni, _type, _mode) |
| #define | CS_REALLOC_HD(_ptr, _ni, _type, _mode) |
| #define | CS_FREE_HD(_ptr) cs_free_hd(_ptr, #_ptr, __FILE__, __LINE__), _ptr = NULL |
| #define | CS_FREE(_ptr) cs_free(_ptr, #_ptr, __FILE__, __LINE__), _ptr = NULL |
| #define | cs_alloc_mode CS_ALLOC_HOST |
| #define | cs_associate_device_ptr(_host_ptr, _ni, _size) ; |
| | Associate device memory with a given host memory pointer. More...
| #define | cs_dissassociate_device_ptr(_host_ptr) ; |
| | Detach device memory from a given host memory pointer. More...
| #define | cs_set_alloc_mode(_host_ptr, mode) ; |
| | Set allocation mode for an already allocated pointer. More...
◆ cs_alloc_mode
◆ cs_associate_device_ptr
| #define cs_associate_device_ptr |
_host_ptr, |
_ni, |
_size |
If the host memory is already associated with the device, the existing device pointer is returned. Otherwise, a new device allocation is called and returned.
- Parameters
| [in] | host_ptr | host pointer |
| [in] | ni | number of elements |
| [in] | size | element size |
- Returns
- pointer to allocated memory.
◆ cs_dissassociate_device_ptr
| #define cs_dissassociate_device_ptr |
_host_ptr | ) |
If the host memory is shared with the device (i.e. using CS_ALLOC_SHARED), device memory stays shared.
- Parameters
◆ CS_FREE
| #define CS_FREE |
_ptr | ) |
◆ CS_FREE_HD
| #define CS_FREE_HD |
_ptr | ) |
◆ CS_MALLOC_HD
| #define CS_MALLOC_HD |
_ptr, |
_ni, |
_type, |
_mode |
Value: #_ptr, __FILE__, __LINE__)
void * cs_malloc_hd(cs_alloc_mode_t mode, size_t ni, size_t size, const char *var_name, const char *file_name, int line_num)
Allocate memory on host and device for ni elements of size bytes.
Definition: cs_base_accel.cxx:336
◆ CS_REALLOC_HD
| #define CS_REALLOC_HD |
_ptr, |
_ni, |
_type, |
_mode |
Value:_ptr = (_type *)
cs_realloc_hd(_ptr, _mode, _ni,
sizeof(_type), \
void * cs_realloc_hd(void *ptr, cs_alloc_mode_t mode, size_t ni, size_t size, const char *var_name, const char *file_name, int line_num)
Reallocate memory on host and device for ni elements of size bytes.
Definition: cs_base_accel.cxx:449
◆ cs_set_alloc_mode
| #define cs_set_alloc_mode |
_host_ptr, |
mode |
If the allocation mode is different from the previous one, the associated memory will be reallocated with the desired mode, and the previous allocation freed.
- Parameters
| [in,out] | host_ptr | pointer to host pointer to modify |
| [in] | mode | desired allocation mode |
◆ cs_alloc_mode_t
| Enumerator |
| CS_ALLOC_HOST | allocation on host only
| CS_ALLOC_HOST_DEVICE | allocation on host and device
| CS_ALLOC_HOST_DEVICE_PINNED | allocation on host and device, using page-locked memory on host if possible
| CS_ALLOC_HOST_DEVICE_SHARED | allocation on host and device, using mapped/shared memory
| CS_ALLOC_DEVICE | allocation on device only
