Field keywords
char * label
int coupled
int moment_id
int time_extrapolated
int limiter_choice
int scalar_id
cs_equation_param_tvar_cal_opt
cs_solving_info_tsolving_info
char * restart_file
int diffusivity_id
double diffusivity_ref
◆ coupled
coupled
If > 0, this variable is coupled using the internal coupling mechanism.
Restricted to fields with CS_FIELD_VARIABLE type.
◆ diffusivity_id
diffusivity_id
Field if of the matching molecular diffusivity for a scalar. Negative value if the field has constant diffusivity.
If set to 0, a matching field will be created and its value reset automatically to that field's id. If set directly to a value > 0, it is assumed that the matching diffusivity field has already been defined and is associated with this scalar. This allows both creating an associated field automatically or in more advanced cases, sharing a diffusivity field between several scalars.
◆ diffusivity_ref
diffusivity_ref
Reference molecular diffusivity for a scalar ( $kg.m^{-1}.s^{-1}$). Negative value if not initialized or used.
Warning
: for a temperature, the diffusivity is defined as $\lambda/C_p$ where $\lambda$ and $C_p$ are the conductivity and specific heat. When using the Graphical Interface, $\lambda$ and $C_p$ are specified separately, and the matching molecular diffusivity is computed automatically.
With the compressible module, diffusivity_ref (given in uscfx2) is directly the thermal conductivity $W.m^{-1}.K^{-1}$.
With gas or coal combustion, the molecular diffusivity of the enthalpy ( $kg.m^{-1}.s^{-1}$) must be specified by the user in the variable ppthch::diftl0 "diftl0"(cs_user_combustion).
With the electric module, for the Joule effect, the diffusivity is specified by the user in cs_user_physical_properties.c (even if it is constant). For the electric arcs, it is calculated from the thermochemical data file.
◆ label
label
Optional label associated to the field; if NULL, name will be used instead.
◆ limiter_choice
limiter_choice
Integer corresponding to the type of Roe-Sweby Limiter:
  • 1: minmod
  • 2: Van-Leer
  • 3: Van-Albada
  • 4: superbee
◆ moment_id
moment_id
If > -1, refers to the field if of which the current field is a time moment (see cs_time_moment.h). If < 0, the current field is not a time moment.
Restricted to fields with both CS_FIELD_VARIABLE and CS_FIELD_POSTPROCESS type.
◆ restart_file
restart_file
Indicates in which restart file the associated info may be found.
If NULL, default rules apply.
◆ scalar_id
scalar_id
Matching scalar id (inverse Fortran isca(iscal) ), or -1 if the field does not represent a solved scalar type variable.
◆ solving_info
solving_info
Structure containing the solving info of the field variables (used for log, not setup, so set NULL setup logging function)
◆ time_extrapolated
time_extrapolated
Is the field time-extrapolated?
  • -1: default automatic value
  • 0: "standard" first-order: the value calculated at the beginning of the current time step (from the variables known at the end of the previous time step) is used
  • 1: second-order: the physical property $\phi$ is extrapolated according to the formula $\phi^{n+\theta}=[(1+\theta)\phi^n-\theta \phi^{n-1}]$, $\theta$ being given by the value of 0.5
  • 2: first-order: the physical property $\phi$ is extrapolated at $n+1$ according to the same formula as when = 1 but with $\theta$ = 1
◆ var_cal_opt
var_cal_opt
Structure containing the equation parameters of a solved variable.
