fvm_writer_priv.h File Reference
#include "cs_timer.h"
#include "fvm_defs.h"
#include "fvm_nodal.h"
#include "fvm_writer.h"
+ Include dependency graph for fvm_writer_priv.h:
Data Structures
struct  fvm_writer_format_t
struct  fvm_writer_t
Macros
#define FVM_WRITER_FORMAT_USE_EXTERNAL   (1 << 0)
#define FVM_WRITER_FORMAT_HAS_POLYGON   (1 << 1)
#define FVM_WRITER_FORMAT_HAS_POLYHEDRON   (1 << 2)
#define FVM_WRITER_FORMAT_SEPARATE_MESHES   (1 << 3)
#define FVM_WRITER_FORMAT_NO_SEPARATE_MESHES   (1 << 4)
#define FVM_WRITER_FORMAT_NAME_IS_OPTIONAL   (1 << 5)
Typedefs
typedef int() fvm_writer_n_version_strings_t(void)
typedef const char *() fvm_writer_version_string_t(int string_index, int compile_time_version)
typedef void *() fvm_writer_init_t(const char *name, const char *path, const char *options, fvm_writer_time_dep_t time_dependency)
typedef void *() fvm_writer_finalize_t(void *this_writer)
typedef void() fvm_writer_set_mesh_time_t(void *this_writer, int time_step, double time_value)
typedef int() fvm_writer_needs_tesselation_t(void *this_writer, const fvm_nodal_t *mesh, fvm_element_t element_type)
typedef void() fvm_writer_export_nodal_t(void *this_writer, const fvm_nodal_t *mesh)
typedef void() fvm_writer_export_field_t(void *this_writer, const fvm_nodal_t *mesh, const char *name, fvm_writer_var_loc_t location, int dimension, cs_interlace_t interlace, int n_parent_lists, const cs_lnum_t parent_num_shift[], cs_datatype_t datatype, int time_step, double time_value, const void *const field_values[])
typedef void() fvm_writer_flush_t(void *this_writer)
◆ FVM_WRITER_FORMAT_HAS_POLYGON
◆ FVM_WRITER_FORMAT_HAS_POLYHEDRON
◆ FVM_WRITER_FORMAT_NAME_IS_OPTIONAL
◆ FVM_WRITER_FORMAT_NO_SEPARATE_MESHES
◆ FVM_WRITER_FORMAT_SEPARATE_MESHES
◆ FVM_WRITER_FORMAT_USE_EXTERNAL
Typedef Documentation
◆ fvm_writer_export_field_t
◆ fvm_writer_export_nodal_t
◆ fvm_writer_finalize_t
typedef void*() fvm_writer_finalize_t(void *this_writer)
◆ fvm_writer_flush_t
◆ fvm_writer_init_t
typedef void*() fvm_writer_init_t(const char *name, const char *path, const char *options, fvm_writer_time_dep_t time_dependency)
◆ fvm_writer_n_version_strings_t
◆ fvm_writer_needs_tesselation_t
◆ fvm_writer_set_mesh_time_t
◆ fvm_writer_version_string_t
typedef const char*() fvm_writer_version_string_t(int string_index, int compile_time_version)
