fvm_writer_priv.h
1 #ifndef __FVM_WRITER_PRIV_H__
2 #define __FVM_WRITER_PRIV_H__
5  * Private types for mesh and field writers
30 #include "cs_defs.h"
33  * Local headers
36 #include "cs_timer.h"
38 #include "fvm_defs.h"
39 #include "fvm_nodal.h"
40 #include "fvm_writer.h"
45
46 /*=============================================================================
47  * Macro definitions
49
50 /*
51  * Writer format implementation and functionality info
52  */
53
54 #define FVM_WRITER_FORMAT_USE_EXTERNAL (1 << 0)
55
56 #define FVM_WRITER_FORMAT_HAS_POLYGON (1 << 1)
57 #define FVM_WRITER_FORMAT_HAS_POLYHEDRON (1 << 2)
58
59 #define FVM_WRITER_FORMAT_SEPARATE_MESHES (1 << 3)
60 #define FVM_WRITER_FORMAT_NO_SEPARATE_MESHES (1 << 4)
61
62 #define FVM_WRITER_FORMAT_NAME_IS_OPTIONAL (1 << 5)
63
64 /*============================================================================
65  * Type definitions
66  *============================================================================*/
67
68 /*----------------------------------------------------------------------------
69  * Function pointer types
70  *----------------------------------------------------------------------------*/
71
72 typedef int
74
75 typedef const char *
76 (fvm_writer_version_string_t)(int string_index,
77  int compile_time_version);
78
79 #if defined(HAVE_MPI)
80
81 typedef void *
82 (fvm_writer_init_t) (const char *name,
83  const char *path,
84  const char *options,
85  fvm_writer_time_dep_t time_dependency,
86  MPI_Comm comm);
87
88 #else
89
90 typedef void *
91 (fvm_writer_init_t) (const char *name,
92  const char *path,
93  const char *options,
94  fvm_writer_time_dep_t time_dependency);
95
96 #endif /* defined(HAVE_MPI) */
97
98 typedef void *
99 (fvm_writer_finalize_t) (void *this_writer);
100
101 typedef void
102 (fvm_writer_set_mesh_time_t) (void *this_writer,
103  int time_step,
104  double time_value);
105
106 typedef int
107 (fvm_writer_needs_tesselation_t) (void *this_writer,
108  const fvm_nodal_t *mesh,
109  fvm_element_t element_type);
110
111 typedef void
112 (fvm_writer_export_nodal_t) (void *this_writer,
113  const fvm_nodal_t *mesh);
114
115 typedef void
116 (fvm_writer_export_field_t) (void *this_writer,
117  const fvm_nodal_t *mesh,
118  const char *name,
119  fvm_writer_var_loc_t location,
120  int dimension,
121  cs_interlace_t interlace,
122  int n_parent_lists,
123  const cs_lnum_t parent_num_shift[],
124  cs_datatype_t datatype,
125  int time_step,
126  double time_value,
127  const void *const field_values[]);
128
129 typedef void
130 (fvm_writer_flush_t) (void *this_writer);
131
132 /*----------------------------------------------------------------------------
133  * Format information structure
134  *----------------------------------------------------------------------------*/
135
136 typedef struct {
137
138  char name[32]; /* Format name */
139  char version[16]; /* Format version (if defined) */
140  int info_mask; /* Additional format info */
141  fvm_writer_time_dep_t max_time_dep; /* Maximum time dependency level
142  possible with this format */
143
144  int dl_count; /* Number of writers using the
145  dynamically loadable library
146  for this format, if relevant */
147  void *dl_lib; /* Pointer to dynamically loadable
148  library, if used */
149  const char *dl_name; /* Prefix for name of dynamically
150  loadable library, or NULL */
151  const char *dl_prefix; /* Prefix for exported symbols of
152  dynamically loadable library,
153  or NULL */
154
164
166
167 /*----------------------------------------------------------------------------
168  * Structure defining a writer definition
169  *----------------------------------------------------------------------------*/
170
172
173  char *name; /* Writer name */
174  fvm_writer_format_t *format; /* Output format */
175  char *options; /* Output options */
176  char *path; /* Output path */
177  fvm_writer_time_dep_t time_dep; /* Geometry time dependency */
178  int n_format_writers; /* number of actual writers */
179  void **format_writer; /* Format-specific writers */
180  char **mesh_names; /* List of mesh names if one
181  writer per mesh is required */
182
183  cs_timer_counter_t mesh_time; /* Meshes output timer */
184  cs_timer_counter_t field_time; /* Fields output timer */
185  cs_timer_counter_t flush_time; /* output "completion" timer */
186
187 };
188
189 /*----------------------------------------------------------------------------*/
190
192
193 #endif /* __FVM_WRITER_PRIV_H__ */
void() fvm_writer_set_mesh_time_t(void *this_writer, int time_step, double time_value)
Definition: fvm_writer_priv.h:102
cs_datatype_t
Definition: cs_defs.h:260
fvm_writer_needs_tesselation_t * needs_tesselation_func
Definition: fvm_writer_priv.h:160
fvm_writer_set_mesh_time_t * set_mesh_time_func
Definition: fvm_writer_priv.h:159
void *() fvm_writer_init_t(const char *name, const char *path, const char *options, fvm_writer_time_dep_t time_dependency)
Definition: fvm_writer_priv.h:91
fvm_writer_finalize_t * finalize_func
Definition: fvm_writer_priv.h:158
Definition: fvm_writer.h:69
int dl_count
Definition: fvm_writer_priv.h:144
cs_interlace_t
Definition: cs_defs.h:467
Definition: fvm_writer_priv.h:136
Definition: fvm_writer_priv.h:171
Definition: cs_defs.h:495
Definition: fvm_writer_priv.h:185
int() fvm_writer_n_version_strings_t(void)
Definition: fvm_writer_priv.h:73
int() fvm_writer_needs_tesselation_t(void *this_writer, const fvm_nodal_t *mesh, fvm_element_t element_type)
Definition: fvm_writer_priv.h:107
fvm_writer_version_string_t * version_string_func
Definition: fvm_writer_priv.h:156
const char * dl_name
Definition: fvm_writer_priv.h:149
Definition: fvm_writer.h:57
Definition: fvm_writer_priv.h:141
fvm_writer_export_field_t * export_field_func
Definition: fvm_writer_priv.h:162
void() fvm_writer_flush_t(void *this_writer)
Definition: fvm_writer_priv.h:130
char * options
Definition: fvm_writer_priv.h:175
Definition: fvm_writer_priv.h:178
fvm_element_t
Definition: fvm_defs.h:48
void() fvm_writer_export_nodal_t(void *this_writer, const fvm_nodal_t *mesh)
Definition: fvm_writer_priv.h:112
int info_mask
Definition: fvm_writer_priv.h:140
Definition: fvm_writer_priv.h:177
const char * dl_prefix
Definition: fvm_writer_priv.h:151
void ** format_writer
Definition: fvm_writer_priv.h:179
void *() fvm_writer_finalize_t(void *this_writer)
Definition: fvm_writer_priv.h:99
fvm_writer_export_nodal_t * export_nodal_func
Definition: fvm_writer_priv.h:161
Definition: cs_defs.h:301
fvm_writer_format_t * format
Definition: fvm_writer_priv.h:174
fvm_writer_flush_t * flush_func
Definition: fvm_writer_priv.h:163
Definition: cs_defs.h:496
char ** mesh_names
Definition: fvm_writer_priv.h:180
fvm_writer_init_t * init_func
Definition: fvm_writer_priv.h:157
char * name
Definition: fvm_writer_priv.h:173
void() fvm_writer_export_field_t(void *this_writer, const fvm_nodal_t *mesh, const char *name, fvm_writer_var_loc_t location, int dimension, cs_interlace_t interlace, int n_parent_lists, const cs_lnum_t parent_num_shift[], cs_datatype_t datatype, int time_step, double time_value, const void *const field_values[])
Definition: fvm_writer_priv.h:116
const char *() fvm_writer_version_string_t(int string_index, int compile_time_version)
Definition: fvm_writer_priv.h:76
Definition: fvm_writer_priv.h:183
char * path
Definition: fvm_writer_priv.h:176
void * dl_lib
Definition: fvm_writer_priv.h:147
fvm_writer_n_version_strings_t * n_version_strings_func
Definition: fvm_writer_priv.h:155
Definition: fvm_writer_priv.h:184
Definition: mesh.f90:26
Definition: cs_timer.h:57
