cs_timer_stats.c File Reference
#include "cs_config.h"
#include <time.h>
#include "cs_map.h"
#include "cs_timer.h"
#include "cs_time_plot.h"
#include "cs_timer_stats.h"
+ Include dependency graph for cs_timer_stats.c:
Macros
#define _POSIX_C_SOURCE   200112L
void cs_timer_stats_initialize (void)
 Initialize timer statistics handling. More...
void cs_timer_stats_finalize (void)
 Finalize timer statistics handling. More...
void cs_timer_stats_set_start_time (int time_id)
 Set a start time for time stats. More...
void cs_timer_stats_set_plot_options (cs_time_plot_format_t format, int frequency, int n_buffer_steps, double flush_wtime)
 Set global timer statistics plot options. More...
void cs_timer_stats_increment_time_step (void)
 Increment time step for timer statistics. More...
int cs_timer_stats_create (const char *parent_name, const char *name, const char *label)
 Create a timer statistics structure. More...
int cs_timer_stats_id_by_name (const char *name)
 Return the id of a defined statistic based on its name. More...
void cs_timer_stats_set_plot (int id, int plot)
 Enable or disable plotting for a timer statistic. More...
int cs_timer_stats_is_active (int id)
 indicate if a timer for a given statistic is currently active. More...
void cs_timer_stats_start (int id)
 Start a timer for a given statistic. More...
void cs_timer_stats_stop (int id)
 Stop a timer for a given statistic. More...
int cs_timer_stats_switch (int id)
 Start a timer for a given statistic, stopping previous timers of the same type which are not a parent, and starting inactive parent timers if necessary. More...
void cs_timer_stats_add_diff (int id, const cs_timer_t *t0, const cs_timer_t *t1)
 Add a timing range to an inactive timer. More...
void cs_timer_stats_define_defaults (void)
 Define default timer statistics. More...
Application timer statistics and graphs.
These statistics are intended to provide a synthetic view of the relative costs of various operations and stages, and are defined as sets of trees so as to allow a form of grouping.
This logic does not replace having specific timers for operators, which allow for more detail, but more difficult to provide an overview for. Timer statistics also allow for incrementing results from base timers (in addition to starting/stopping their own timers), so they may be used to assist logging and plotting of other timers.
◆ _POSIX_C_SOURCE
◆ cs_timer_stats_add_diff()
void cs_timer_stats_add_diff ( int  id,
const cs_timer_t t0,
const cs_timer_t t1
This does not modify parent timers, so consistency of active and inactive timers must be ensured by the caller.
[in]idid of statistic
[in]t0oldest timer value
[in]t1most recent timer value
◆ cs_timer_stats_create()
int cs_timer_stats_create ( const char *  parent_name,
const char *  name,
const char *  label
[in]parent_namename of parent statistic, or NULL
[in]nameassociated canonical name
[in]labelassociated label, or NULL
id of new timer stats structure
◆ cs_timer_stats_define_defaults()
void cs_timer_stats_define_defaults ( void  )
This creates 2 statistic timer trees, whose roots ids are:
  • 0 for computational operations
  • 1 for computational stages
◆ cs_timer_stats_finalize()
void cs_timer_stats_finalize ( void  )
◆ cs_timer_stats_id_by_name()
int cs_timer_stats_id_by_name ( const char *  name)
If no timer with the given name exists, -1 is returned.
[in]namestatitic name
id of the statistic, or -1 if not found
◆ cs_timer_stats_increment_time_step()
void cs_timer_stats_increment_time_step ( void  )
◆ cs_timer_stats_initialize()
void cs_timer_stats_initialize ( void  )
◆ cs_timer_stats_is_active()
int cs_timer_stats_is_active ( int  id)
1 if active, 0 otherwise
◆ cs_timer_stats_set_plot()
void cs_timer_stats_set_plot ( int  id,
int  plot
By default plotting is enabled for all statistics, except root statistic 1 (as it measures the same total time as root 0, with a different subtree).
This function is only effective before the first call to cs_timer_stats_increment_time_step.
[in]plot0 to disable, 1 to enable
◆ cs_timer_stats_set_plot_options()
void cs_timer_stats_set_plot_options ( cs_time_plot_format_t  format,
int  frequency,
int  n_buffer_steps,
double  flush_wtime
[in]formatassociated file format
[in]frequencyplot every n time steps
[in]n_buffer_stepsnumber of time steps in output buffer if file is not to be kept open
[in]flush_wtimeelapsed time interval between file flushes (if < 0, no forced flush)
◆ cs_timer_stats_set_start_time()
void cs_timer_stats_set_start_time ( int  time_id)
This is useful to shift the time id for restarts. This function must not be called after cs_timer_stats_increment_time_step.
[in]time_idassociated starting time id
◆ cs_timer_stats_start()
void cs_timer_stats_start ( int  id)
Parents of the current statistic are also started, if not active.
If a timer with the same root but different parents is active, we assume the current operation is a subset of the active timer, so the timer is not started, so as to avoid having a sum of parts larger than the total.
◆ cs_timer_stats_stop()
void cs_timer_stats_stop ( int  id)
Children of the current statistic are also stopped, if active.
◆ cs_timer_stats_switch()
int cs_timer_stats_switch ( int  id)
[in]idid of statistic with same root
id of previously active statistic, or -1 in case of error
