Include dependency graph for cs_stl.h:Go to the source code of this file.
| struct | cs_stl_mesh_t |
| struct | cs_stl_mesh_info_t |
| cs_stl_mesh_t * | cs_stl_mesh_add (const char *path) |
| Add a new STL mesh structure. More... | |
| cs_stl_mesh_t * | cs_stl_mesh_get_by_name (const char *name) |
| Return a pointer to a STL mesh based on its name if present. More... | |
| void | cs_stl_mesh_destroy_all (void) |
| Free all allocated STL mesh structures. More... | |
| void | cs_stl_file_read (cs_stl_mesh_t *stl_mesh, const char *path) |
| Read a binary STL file and store its content in a STL mesh structure. More... | |
| void | cs_stl_mesh_transform (cs_stl_mesh_t *stl_mesh, double matrix[3][4]) |
| Apply a transformation matrix to a STL mesh structure. More... | |
| void | cs_stl_mesh_transform_from_init (cs_stl_mesh_t *stl_mesh, double matrix[3][4]) |
| Apply a transformation matrix to a STL mesh structure, but use. More... | |
| void | cs_stl_mesh_translate (cs_stl_mesh_t *stl_mesh, double vector[3]) |
| Apply a translation to a STL mesh structure. More... | |
| void | cs_stl_mesh_rotate (cs_stl_mesh_t *stl_mesh, double theta, double axis[3], double center[3]) |
| Apply a rotation to a STL mesh structure. More... | |
| void | cs_stl_mesh_scale (cs_stl_mesh_t *stl_mesh, double scale) |
| Apply a scaling to a STL mesh structure. More... | |
| void | cs_stl_set_porosity_seed (cs_stl_mesh_t *stl_mesh, int n_points, cs_real_t *coords) |
| Set the points outside he STL geometry. Those points will be used as. More... | |
| void | cs_stl_post_init_writer (const char *case_name, const char *dir_name, const char *fmt_name, const char *fmt_opts, fvm_writer_time_dep_t time_dep, bool output_at_start, bool output_at_end, int frequency_n, double frequency_t) |
| Create a new writer that will contains the STL mesh added by the user. More... | |
| void | cs_stl_post_add_mesh (cs_stl_mesh_t *stl_mesh) |
| Associate a STL mesh to the default writer. More... | |
| void | cs_stl_file_write (cs_stl_mesh_t *stl_mesh, const char *path) |
| Write a binary STL file according to a given STL mesh structure. More... | |
| void | cs_stl_intersection (cs_stl_mesh_t *stl_mesh, cs_lnum_t n_input, cs_lnum_t *input_idx, cs_lnum_t *n_selected_cells, cs_lnum_t *selected_cells, cs_lnum_t *tria_in_cell_idx, cs_lnum_t **tria_in_cell_lst, cs_lnum_t *max_size) |
| Compute intersection between a STL mesh and the main mesh. More... | |
| void | cs_stl_refine (cs_stl_mesh_t *stl_mesh, int n_ref) |
| Refine the mesh following a given STL mesh. More... | |
| void | cs_stl_compute_porosity (cs_stl_mesh_t *stl_mesh, cs_real_t *porosity, int *indic) |
| Compute porosity field according to a given STL mesh. More... | |
| cs_stl_mesh_info_t * | cs_glob_stl_meshes |
| void cs_stl_compute_porosity | ( | cs_stl_mesh_t * | stl_mesh, |
| cs_real_t * | porosity, | ||
| int * | indic | ||
| [in] | stl_mesh | pointer to the associated STL mesh structure |
| [out] | porosity | interpolated porosity field |
| [out] | indic | indicator of the STL location |
| void cs_stl_file_read | ( | cs_stl_mesh_t * | stl_mesh, |
| const char * | path | ||
Each STL file composed of the following header:
uint8[80] – Header uint32 – Number of triangles
followed by 50 byte blocks for each triangle:
| [in] | path | path to the STL file |
| void cs_stl_file_write | ( | cs_stl_mesh_t * | stl_mesh, |
| void cs_stl_intersection | ( | cs_stl_mesh_t * | stl_mesh, |
| cs_lnum_t | n_input, | ||
| cs_lnum_t * | input_idx, | ||
| cs_lnum_t * | n_selected_cells, | ||
| cs_lnum_t * | selected_cells, | ||
| cs_lnum_t * | tria_in_cell_idx, | ||
| cs_lnum_t ** | tria_in_cell_lst, | ||
| cs_lnum_t * | max_size | ||
| [in] | n_input | number of cells on which intersection is done |
| [in] | input_idx | index of input cells (size: input_idx) |
| [out] | n_selected_cells | number of output intersecting cells |
| [out] | selected_cells | index of output cells (size: output_idx) |
| [out] | tria_in_cell_idx | start index of triangle intersecting each cell (size: n_output) |
| [out] | tria_in_cell_lst | list of triangles in intersecting cells |
| [in,out] | max_size | maximum size of tria_in_cell_lst array |
| cs_stl_mesh_t* cs_stl_mesh_add | ( | const char * | name | ) |
| [in] | name | name of the STL mesh |
| void cs_stl_mesh_destroy_all | ( | void | ) |
| cs_stl_mesh_t* cs_stl_mesh_get_by_name | ( | const char * | name | ) |
If no STL mesh of the given name is defined, NULL is returned.
| void cs_stl_mesh_rotate | ( | cs_stl_mesh_t * | stl_mesh, |
| double | theta, | ||
| double | axis[3], | ||
| double | center[3] | ||
| [in] | theta | rotation angle |
| [in] | axis | rotation axis |
| [in] | center | rotation center |
| void cs_stl_mesh_scale | ( | cs_stl_mesh_t * | stl_mesh, |
| double | scale | ||
| [in] | vector | translation vector |
| void cs_stl_mesh_transform | ( | cs_stl_mesh_t * | stl_mesh, |
| double | matrix[3][4] | ||
| [in] | matrix | transformation matrix |
| void cs_stl_mesh_transform_from_init | ( | cs_stl_mesh_t * | stl_mesh, |
the initial coordinates as inputs
| void cs_stl_mesh_translate | ( | cs_stl_mesh_t * | stl_mesh, |
| cs_real_t | vector[3] | ||
| void cs_stl_post_add_mesh | ( | cs_stl_mesh_t * | stl_mesh | ) |
| void cs_stl_post_init_writer | ( | const char * | case_name, |
| const char * | dir_name, | ||
| const char * | fmt_name, | ||
| const char * | fmt_opts, | ||
| fvm_writer_time_dep_t | time_dep, | ||
| bool | output_at_start, | ||
| bool | output_at_end, | ||
| int | frequency_n, | ||
| double | frequency_t | ||
The writer_id is stored in the cs_glob_stl_meshes structure.
| [in] | time_dep | > 1 if the writer is transient, else writer is fixed |
| void cs_stl_refine | ( | cs_stl_mesh_t * | stl_mesh, |
| int | n_ref | ||
| [in] | n_ref | level of refinement |
| void cs_stl_set_porosity_seed | ( | cs_stl_mesh_t * | stl_mesh, |
| int | n_points, | ||
| cs_real_t * | coords | ||
seeds to propagate porosity values outside the STL geometry.
| [in] | n_points | number of points |
| [in] | coords | coordinates (x1,y1,z1,...,xn,yn,zn) (size : 3*n_point) |
| cs_stl_mesh_info_t* cs_glob_stl_meshes |
