cs_stl_mesh_t Struct Reference
#include <cs_stl.h>
+ Collaboration diagram for cs_stl_mesh_t:
Data Fields
char name [20]
char header [80]
cs_lnum_t n_faces
cs_real_3_tcoords
cs_real_3_tcoords_ini
int n_seeds
cs_real_tseed_coords
bool is_porous
fvm_nodal_t * ext_mesh
Field Documentation
◆ coords
cs_real_3_t* coords
Array of face vertex coordinates coord[n_vertices][3]
◆ coords_ini
cs_real_3_t* coords_ini
Array of face vertex coordinates at init coord_ini[n_vertices][3]
◆ ext_mesh
fvm_nodal_t* ext_mesh
Associated external mesh
◆ header
char header[80]
Header of the STL file
◆ is_porous
bool is_porous
If true the STL is used for porosity computation. (Default : False)
◆ n_faces
cs_lnum_t n_faces
Number of triangles
◆ n_seeds
int n_seeds
Number of prescribed points outside the STL
◆ name
char name[20]
Name identifier of the STL file
◆ seed_coords
cs_real_t* seed_coords
Coordinates of the reference seed points seed_coords[n_seed][3]
