cs_sles_amgx.h File Reference
#include "cs_matrix.h"
#include "cs_sles.h"
+ Include dependency graph for cs_sles_amgx.h:
Macros
#define CS_SLES_AMGX_PREFER_COMM_FROM_MAPS   (1 << 0)
Typedefs
typedef struct _cs_sles_amgx_t cs_sles_amgx_t
cs_sles_amgx_tcs_sles_amgx_define (int f_id, const char *name)
 Define and associate an AmgX linear system solver for a given field or equation name. More...
cs_sles_amgx_tcs_sles_amgx_create (void)
 Create AmgX linear system solver info and context. More...
void * cs_sles_amgx_copy (const void *context)
 Create AmgX linear system solver info and context based on existing info and context. More...
void cs_sles_amgx_destroy (void **context)
 Destroy AmgX linear system solver info and context. More...
const char * cs_sles_amgx_get_config (void *context)
 return the solver configuration for an AmgX solver. More...
void cs_sles_amgx_set_config (void *context, const char *config)
 Define the configuration for an AmgX solver. More...
const char * cs_sles_amgx_get_config_file (void *context)
 return the name of the solver configuration file for an AmgX solver. More...
void cs_sles_amgx_set_config_file (void *context, const char *path)
 Set the solver configuration file for an AmgX solver. More...
bool cs_sles_amgx_get_pin_memory (void *context)
 Indicate whether an AmgX solver should pin host memory. More...
void cs_sles_amgx_set_pin_memory (void *context, bool pin_memory)
 Define whether an AmgX solver should pin host memory. More...
bool cs_sles_amgx_get_use_device (void *context)
 Define whether an AmgX solver should use the device or host. More...
void cs_sles_amgx_set_use_device (void *context, bool use_device)
void cs_sles_amgx_set_flags (void *context, int flags)
 Define additional AmgX solver usage flags. More...
int cs_sles_amgx_get_flags (void *context)
 Query additional AmgX solver usage flags. More...
void cs_sles_amgx_setup (void *context, const char *name, const cs_matrix_t *a, int verbosity)
 Setup AmgX linear equation solver. More...
cs_sles_convergence_state_t cs_sles_amgx_solve (void *context, const char *name, const cs_matrix_t *a, int verbosity, cs_halo_rotation_t rotation_mode, double precision, double r_norm, int *n_iter, double *residue, const cs_real_t *rhs, cs_real_t *vx, size_t aux_size, void *aux_vectors)
 Call AmgX linear equation solver. More...
void cs_sles_amgx_free (void *context)
 Free AmgX linear equation solver setup context. More...
void cs_sles_amgx_log (const void *context, cs_log_t log_type)
 Log sparse linear equation solver info. More...
◆ CS_SLES_AMGX_PREFER_COMM_FROM_MAPS
AmgX wrapper option flags
Use AMGX_comm_from_maps_1_ring instead of AMGX_distribution for parallel matrices when its use seems possible
Typedef Documentation
◆ cs_sles_amgx_t
◆ cs_sles_amgx_copy()
void* cs_sles_amgx_copy ( const void *  context)
[in]contextpointer to reference info and context (actual type: cs_sles_amgx_t *)
pointer to newly created solver info object. (actual type: cs_sles_amgx_t *)
◆ cs_sles_amgx_create()
cs_sles_amgx_t* cs_sles_amgx_create ( void  )
pointer to associated linear system object.
◆ cs_sles_amgx_define()
cs_sles_amgx_t* cs_sles_amgx_define ( int  f_id,
const char *  name
This is a utility function: if finer control is needed, see cs_sles_define and cs_sles_amgx_create.
[in]nameassociated name if f_id < 0, or NULL
pointer to newly created AmgX solver info object.
◆ cs_sles_amgx_destroy()
void cs_sles_amgx_destroy ( void **  context)
[in,out]contextpointer to AmgX solver info and context (actual type: cs_sles_amgx_t **)
◆ cs_sles_amgx_free()
void cs_sles_amgx_free ( void *  context)
[in,out]contextpointer to AmgX solver info and context (actual type: cs_sles_amgx_t *)
◆ cs_sles_amgx_get_config()
const char* cs_sles_amgx_get_config ( void *  context)
Check the AmgX docummentation for configuration strings syntax.
◆ cs_sles_amgx_get_config_file()
const char* cs_sles_amgx_get_config_file ( void *  context)
Check the AmgX docummentation for configuration file syntax.
configuration file name, or NULL
◆ cs_sles_amgx_get_flags()
int cs_sles_amgx_get_flags ( void *  context)
[in]contextpointer to AmgX solver info and context
associated flags
◆ cs_sles_amgx_get_pin_memory()
bool cs_sles_amgx_get_pin_memory ( void *  context)
By default, host memory will be pinned for faster transfers. This setting is relevant only when not using unified memory.
true for device, false for host only
◆ cs_sles_amgx_get_use_device()
bool cs_sles_amgx_get_use_device ( void *  context)
By default, the device will be used, but by callingg this function with "use_device = false", only the host will be used.
◆ cs_sles_amgx_log()
void cs_sles_amgx_log ( const void *  context,
cs_log_t  log_type
[in]contextpointer to AmgX solver info and context (actual type: cs_sles_amgx_t *)
[in]log_typelog type
◆ cs_sles_amgx_set_config()
void cs_sles_amgx_set_config ( void *  context,
const char *  config
If this function is not called, a default configuration will be used.
[in]configstring defining configuration to use
◆ cs_sles_amgx_set_config_file()
void cs_sles_amgx_set_config_file ( void *  context,
const char *  path
[in]pathpath to configuration file
◆ cs_sles_amgx_set_flags()
void cs_sles_amgx_set_flags ( void *  context,
int  flags
[in]flagsflags (sum/bitwise of) for AmgX usage options.
◆ cs_sles_amgx_set_pin_memory()
void cs_sles_amgx_set_pin_memory ( void *  context,
bool  pin_memory
By default, host memory will be pinned for faster transfers, but by calling this function with "pin_memory = false", this may be deactivated. This setting is relevant only when not using unified memory.
[in]pin_memorytrue for devince, false for host only
◆ cs_sles_amgx_set_use_device()
void cs_sles_amgx_set_use_device ( void *  context,
bool  use_device
[in]use_devicetrue for devince, false for host only
◆ cs_sles_amgx_setup()
void cs_sles_amgx_setup ( void *  context,
const char *  name,
const cs_matrix_t a,
int  verbosity
[in]namepointer to system name
[in]aassociated matrix
[in]verbosityassociated verbosity
◆ cs_sles_amgx_solve()
cs_sles_convergence_state_t cs_sles_amgx_solve ( void *  context,
const char *  name,
int  verbosity,
double  precision,
double  r_norm,
int *  n_iter,
double *  residue,
const cs_real_t rhs,
cs_real_t vx,
size_t  aux_size,
void *  aux_vectors
Warning
The precision, r_norm, and n_iter parameters are ignored here. the matching configuration options should be set earlier, using the cs_sles_amgx_set_config function
[in]amatrix
[in]rotation_modehalo update option for rotational periodicity
[in]precisionsolver precision
[in]r_normresidue normalization
[out]residueresidue
[in]rhsright hand side
[in,out]vxsystem solution
[in]aux_sizenumber of elements in aux_vectors (in bytes)
aux_vectorsoptional working area (internal allocation if NULL)
convergence state
