1 #ifndef __CS_SLES_AMGX_H__ 2 #define __CS_SLES_AMGX_H__ 52 #define CS_SLES_AMGX_PREFER_COMM_FROM_MAPS (1 << 0) void cs_sles_amgx_set_pin_memory(void *context, bool pin_memory)
Define whether an AmgX solver should pin host memory.
Definition: cs_sles_amgx.c:1071
cs_sles_amgx_t * cs_sles_amgx_define(int f_id, const char *name)
Define and associate an AmgX linear system solver for a given field or equation name.
Definition: cs_sles_amgx.c:740
cs_halo_rotation_t
Definition: cs_halo.h:60
void cs_sles_amgx_free(void *context)
Free AmgX linear equation solver setup context.
Definition: cs_sles_amgx.c:1534
Definition: cs_defs.h:495
void cs_sles_amgx_log(const void *context, cs_log_t log_type)
Log sparse linear equation solver info.
Definition: cs_sles_amgx.c:1566
void cs_sles_amgx_set_use_device(void *context, bool use_device)
Define whether an AmgX solver should use the device or host.
Definition: cs_sles_amgx.c:1116
void cs_sles_amgx_setup(void *context, const char *name, const cs_matrix_t *a, int verbosity)
Setup AmgX linear equation solver.
Definition: cs_sles_amgx.c:1186
Definition: cs_defs.h:307
Definition: cs_matrix.h:94
cs_sles_convergence_state_t
Convergence status indicator.
Definition: cs_sles.h:56
double precision, save a
const char * cs_sles_amgx_get_config(void *context)
return the solver configuration for an AmgX solver.
Definition: cs_sles_amgx.c:919
cs_log_t
Definition: cs_log.h:48
void cs_sles_amgx_set_config_file(void *context, const char *path)
Set the solver configuration file for an AmgX solver.
Definition: cs_sles_amgx.c:1024
bool cs_sles_amgx_get_use_device(void *context)
Definition: cs_sles_amgx.c:1090
void cs_sles_amgx_destroy(void **context)
Destroy AmgX linear system solver info and context.
Definition: cs_sles_amgx.c:863
const char * cs_sles_amgx_get_config_file(void *context)
return the name of the solver configuration file for an AmgX solver.
Definition: cs_sles_amgx.c:1003
int cs_sles_amgx_get_flags(void *context)
Query additional AmgX solver usage flags.
Definition: cs_sles_amgx.c:1147
Definition: cs_defs.h:496
struct _cs_sles_amgx_t cs_sles_amgx_t
Definition: cs_sles_amgx.h:60
void * cs_sles_amgx_copy(const void *context)
Create AmgX linear system solver info and context based on existing info and context.
Definition: cs_sles_amgx.c:824
bool cs_sles_amgx_get_pin_memory(void *context)
Indicate whether an AmgX solver should pin host memory.
Definition: cs_sles_amgx.c:1050
void cs_sles_amgx_set_config(void *context, const char *config)
Define the configuration for an AmgX solver.
Definition: cs_sles_amgx.c:978
cs_sles_convergence_state_t cs_sles_amgx_solve(void *context, const char *name, const cs_matrix_t *a, int verbosity, cs_halo_rotation_t rotation_mode, double precision, double r_norm, int *n_iter, double *residue, const cs_real_t *rhs, cs_real_t *vx, size_t aux_size, void *aux_vectors)
Call AmgX linear equation solver.
Definition: cs_sles_amgx.c:1338
void cs_sles_amgx_set_flags(void *context, int flags)
Define additional AmgX solver usage flags.
Definition: cs_sles_amgx.c:1166
cs_sles_amgx_t * cs_sles_amgx_create(void)
Create AmgX linear system solver info and context.
Definition: cs_sles_amgx.c:774
