cs_restart_map.c File Reference
#include <mpi.h>
#include "fvm_nodal.h"
#include "ple_locator.h"
#include "cs_io.h"
#include "cs_coupling.h"
#include "cs_mesh_connect.h"
#include "cs_mesh_location.h"
#include "cs_preprocessor_data.h"
#include "cs_timer.h"
#include "cs_timer_stats.h"
#include "cs_restart.h"
#include "cs_restart_map.h"
+ Include dependency graph for cs_restart_map.c:
void cs_restart_map_set_mesh_input (const char *mesh_path)
 Indicate restart files should be mapped to a given mesh input. More...
void cs_restart_map_set_options (float tolerance_base, float tolerance_fraction)
 Set options relative to restart file mapping to a given mesh input. More...
void cs_restart_map_build (void)
 Build mapping of restart files to different mesh if defined. More...
void cs_restart_map_free (void)
 Free restart file mapping to different mesh. More...
◆ cs_restart_map_build()
void cs_restart_map_build ( void  )
◆ cs_restart_map_free()
void cs_restart_map_free ( void  )
Revert restart reading to default behavior.
◆ cs_restart_map_set_mesh_input()
void cs_restart_map_set_mesh_input ( const char *  mesh_path)
[in]mesh_pathpath to mesh input
◆ cs_restart_map_set_options()
void cs_restart_map_set_options ( float  tolerance_base,
[in]tolerance_baseassociated base tolerance (used for bounding box check only, not for location test)
[in]tolerance_fractionassociated fraction of element bounding boxes added to tolerance
