cs_preprocessor_data.h
1 #ifndef __CS_PRE_PROCESSOR_DATA_H__
2 #define __CS_PRE_PROCESSOR_DATA_H__
5  * Exchange of data between Code_Saturne Kernel and Preprocessor
35  * Local headers
38 #include "fvm_io_num.h"
40 #include "cs_base.h"
41 #include "cs_mesh.h"
46
48  * Public function prototypes for Fortran API
50
51 /*----------------------------------------------------------------------------
52  * Pass information relative to mesh metadata to the Fortran API
53  *
54  * Fortran Interface:
55  *
56  * subroutine ledevi(iperio, iperot)
57  * *****************
58  *
59  * integer iperio : <-- : Periodicity indicator
60  * integer iperot : <-- : Number of rotation periodicities
61  *----------------------------------------------------------------------------*/
62
63 void
64 CS_PROCF(ledevi, LEDEVI)(int *iperio,
65  int *iperot);
66
67 /*============================================================================
68  * Public function prototypes
69  *============================================================================*/
70
71 /*----------------------------------------------------------------------------
72  * Define input mesh file to read.
73  *
74  * If this function is never called, the default file is read.
75  * The first time this function is called, this default is overriden by the
76  * defined file, and all subsequent calls define additional meshes to read.
77  *
78  * parameters:
79  * file_name <-- name of file to read
80  * n_group_renames <-- number of groups to rename
81  * group_rename <-- old (group_rename[i*2]) to new (group_rename[i*2 + 1])
82  * group names array (size: n_group_renames*2)
83  * transf_matrix <-- coordinate transformation matrix (or NULL)
84  *----------------------------------------------------------------------------*/
85
86 void
87 cs_preprocessor_data_add_file(const char *file_name,
88  size_t n_group_renames,
89  const char **group_rename,
90  const double transf_matrix[3][4]);
91
92 /*----------------------------------------------------------------------------
93  * Check for periodicity information in mesh meta-data.
94  *
95  * returns:
96  * 0 if no periodicity is present in mesh input,
97  * 1 for translation periodicity only,
98  * 2 for rotation or mixed periodicity
99  *----------------------------------------------------------------------------*/
100
101 int
103
104 /*----------------------------------------------------------------------------*/
111 /*----------------------------------------------------------------------------*/
112
113 bool
115
116 /*----------------------------------------------------------------------------
117  * Read mesh meta-data.
118  *
119  * parameters:
120  * mesh <-- pointer to mesh structure
121  * mesh_builder <-- pointer to mesh builder structure
122  *----------------------------------------------------------------------------*/
123
124 void
126  cs_mesh_builder_t *mesh_builder);
127
128 /*----------------------------------------------------------------------------
129  * Read pre-processor mesh data and finalize input.
130  *
131  * At this stage, ghost cells are not generated yet, so the interior
132  * face connectivity is not complete near parallel domain or periodic
133  * boundaries. Also, isolated faces, if present, are considered to be
134  * boundary faces, as they may participate in future mesh joining
135  * operations. Their matching cell number will be set to -1.
136  * Remaining isolated faces should be removed before completing
137  * the mesh structure.
138  *
139  * parameters:
140  * mesh <-- pointer to mesh structure
141  * mesh_builder <-- pointer to mesh builder structure
142  *----------------------------------------------------------------------------*/
143
144 void
146  cs_mesh_builder_t *mesh_builder);
147
148 /*----------------------------------------------------------------------------*/
149
151
152 #endif /* __CS_PRE_PROCESSOR_DATA_H__ */
153
void cs_preprocessor_data_read_headers(cs_mesh_t *mesh, cs_mesh_builder_t *mesh_builder)
Definition: cs_preprocessor_data.c:2177
int cs_preprocessor_check_perio(void)
Definition: cs_preprocessor_data.c:2119
Definition: cs_mesh_builder.h:57
integer, save iperot
number of rotation periodicities. automaticly evaluated. default value is 0
Definition: period.f90:44
bool cs_preprocessor_data_is_restart(void)
Check if the last preprocessing data defined or read is restart data.
Definition: cs_preprocessor_data.c:2163
Definition: cs_defs.h:495
Definition: cs_mesh.h:84
void cs_preprocessor_data_read_mesh(cs_mesh_t *mesh, cs_mesh_builder_t *mesh_builder)
Definition: cs_preprocessor_data.c:2243
void cs_preprocessor_data_add_file(const char *file_name, size_t n_group_renames, const char **group_rename, const double transf_matrix[3][4])
Definition: cs_preprocessor_data.c:2009
integer, save iperio
presence of periodicity.
Definition: period.f90:40
Definition: cs_defs.h:496
#define CS_PROCF(x, y)
Definition: cs_defs.h:509
Definition: mesh.f90:26
void ledevi(int *iperio, int *iperot)
Definition: cs_preprocessor_data.c:1966
