cs_restart_default.h File Reference
#include "cs_map.h"
#include "cs_restart.h"
+ Include dependency graph for cs_restart_default.h:
Enumerations
enum  cs_restart_file_t {
  CS_RESTART_DISABLED = -1, CS_RESTART_MAIN = 0, CS_RESTART_AUXILIARY = 1, CS_RESTART_RAD_TRANSFER = 2,
  CS_RESTART_LAGR = 3, CS_RESTART_LAGR_STAT = 4, CS_RESTART_1D_WALL_THERMAL = 5, CS_RESTART_LES_INFLOW = 6,
  CS_RESTART_N_RESTART_FILES = 7
void cs_restart_read_field_info (cs_restart_t *r, cs_map_name_to_id_t **old_field_map)
 Read field metadata from checkpoint. More...
void cs_restart_write_field_info (cs_restart_t *r)
 Write field metadata to main checkpoint. More...
void cs_restart_read_variables (cs_restart_t *r, const cs_map_name_to_id_t *old_field_map, int t_id_flag, int read_flag[])
 Read variables from checkpoint. More...
void cs_restart_write_variables (cs_restart_t *r, int t_id_flag, int write_flag[])
 Write variables to checkpoint. More...
void cs_restart_read_linked_fields (cs_restart_t *r, const cs_map_name_to_id_t *old_field_map, const char *key, int read_flag[])
 Read fields depending on others from checkpoint. More...
int cs_restart_write_linked_fields (cs_restart_t *r, const char *key, int write_flag[])
 Write fields depending on others to checkpoint. More...
void cs_restart_read_bc_coeffs (cs_restart_t *r)
 Read boundary condition coefficients for all fields from checkpoint. More...
void cs_restart_write_bc_coeffs (cs_restart_t *r)
 Write boundary condition coefficients for all fields to checkpoint. More...
int cs_restart_read_field_vals (cs_restart_t *r, int f_id, int t_id)
 Read field values from checkpoint. More...
void cs_restart_write_field_vals (cs_restart_t *r, int f_id, int t_id)
 Write field values to checkpoint. More...
void cs_restart_read_time_step_info (cs_restart_t *r)
 Read restart time step info. More...
void cs_restart_write_fields (cs_restart_t *r, cs_restart_file_t r_id)
 Loop over all fields and save them in the restart file which id is passed in argument if it matches their "restart_file" key value. More...
void cs_restart_read_fields (cs_restart_t *r, cs_restart_file_t r_id)
 Loop over all fields and read them in the restart file which id is passed in argument if it matches their "restart_file" key value. More...
◆ cs_restart_file_t
Restart file ids
Enumerator
CS_RESTART_DISABLED
no values to save
CS_RESTART_MAIN
save values in main restart file
save values in auxiliary restart file
save values in radiative transfer restart file
CS_RESTART_LAGR
save values in lagrangian restart file
save values in restart file for lagrangian statistics
save values in 1D wall thermal restart file
save values in LES inflow restart file
Number of types of restart file
◆ cs_restart_read_bc_coeffs()
void cs_restart_read_bc_coeffs ( cs_restart_t r)
[in,out]rassociated restart file pointer
◆ cs_restart_read_field_info()
void cs_restart_read_field_info ( cs_restart_t r,
cs_map_name_to_id_t **  old_field_map
Old ids associated to each field are determined for future use. Note that when reading legacy files (Code_Saturne version 3.3 and below), the old id will actually be the old scalar id (-1 for others).
[out]old_field_mapname to id map of fields in restart file
◆ cs_restart_read_field_vals()
int cs_restart_read_field_vals ( cs_restart_t r,
int  f_id,
int  t_id
If the values are not found using the default rules based on the field's name, its name itself, or a "restart_rename" keyed string value, an old name may be used for compatibility with older files. For cell-based fields, the old name base is appended automatically with "_ce_phase01", except for scalars, where the name uses a different scheme, based on "scalaire_ce_%04" % s_num;
[in]f_idfield id
[in]t_idtime id (0 for current, 1 for previous, ...)
CS_RESTART_SUCCESS in case of success, CS_RESTART_ERR_... otherwise
◆ cs_restart_read_fields()
void cs_restart_read_fields ( cs_restart_t r,
[in]r_idvalue of the key "restart_file"
◆ cs_restart_read_linked_fields()
void cs_restart_read_linked_fields ( cs_restart_t r,
const cs_map_name_to_id_t old_field_map,
const char *  key,
int  read_flag[]
Old ids associate to each field are determined for future use. Note that when reading legacy files (Code_Saturne version 3.3 and below), the old id will actually be the old scalar id (-1 for others).
[in]old_field_mapname to id map of fields in restart file
[in]keykey for field association
[in,out]read_flagoptional flag to track fields read, or NULL; set to sum of 2^time_id for fields read, -1 for fields failed to read (size: n_fields)
◆ cs_restart_read_time_step_info()
void cs_restart_read_time_step_info ( cs_restart_t r)
◆ cs_restart_read_variables()
void cs_restart_read_variables ( cs_restart_t r,
int  t_id_flag,
int  read_flag[]
[in]t_id_flag-1: all time values; 0: current values; > 0: previous values
[in,out]read_flagoptional flag to track fields read, or NULL; set to sum of 2^time_id for fields read (size: n_fields)
◆ cs_restart_write_bc_coeffs()
void cs_restart_write_bc_coeffs ( cs_restart_t r)
◆ cs_restart_write_field_info()
void cs_restart_write_field_info ( cs_restart_t r)
◆ cs_restart_write_field_vals()
void cs_restart_write_field_vals ( cs_restart_t r,
int  f_id,
int  t_id
[in]f_idfield id
◆ cs_restart_write_fields()
void cs_restart_write_fields ( cs_restart_t r,
◆ cs_restart_write_linked_fields()
int cs_restart_write_linked_fields ( cs_restart_t r,
const char *  key,
int  write_flag[]
[in,out]write_flagoptional flag to track fields written, or NULL; set to sum of 2^time_id for fields written (size: n_fields)
number of fields written
◆ cs_restart_write_variables()
void cs_restart_write_variables ( cs_restart_t r,
int  t_id_flag,
int  write_flag[]
