#include <bft_error.h>
#include <bft_mem.h>
#include "cs_fp_exception.h"
#include "cs_multigrid.h"
#include "cs_sles.h"
#include "cs_param_sles.h"
cs_param_sles_t * | cs_param_sles_create (int field_id, const char *system_name) |
Create a cs_param_sles_t structure and assign a default settings. More... | |
void | cs_param_sles_free (cs_param_sles_t **p_slesp) |
Free a cs_param_sles_t structure. More... | |
void | cs_param_sles_log (cs_param_sles_t *slesp) |
Log information related to the linear settings stored in the structure. More... | |
void | cs_param_sles_copy_from (cs_param_sles_t *src, cs_param_sles_t *dst) |
Copy a cs_param_sles_t structure from src to dst. More... | |
void | cs_equation_param_set_saturne_sles (bool use_field_id, cs_param_sles_t *slesp) |
Set parameters for initializing SLES structures used for the resolution of the linear system. Case of saturne's own solvers. More... | |
void | cs_equation_param_set_mumps_sles (bool use_field_id, cs_param_sles_t *slesp) |
Set parameters for initializing SLES structures used for the resolution of the linear system. Case of MUMPS's own solvers. More... | |
void | cs_equation_param_set_petsc_hypre_sles (bool use_field_id, cs_param_sles_t *slesp) |
Set parameters for initializing SLES structures used for the resolution of the linear system. Case of PETSc and Hypre families of solvers. More... | |
int | cs_param_sles_set (bool use_field_id, cs_param_sles_t *slesp) |
Define cs_sles_t structure in accordance with the settings of a cs_param_sles_t structure (SLES = Sparse Linear Equation Solver) More... | |
void cs_equation_param_set_mumps_sles | ( | bool | use_field_id, |
cs_param_sles_t * | slesp | ||
[in] | use_field_id | if false use system name |
[in,out] | slesp | pointer to a cs_param_sles_t structure |
void cs_equation_param_set_petsc_hypre_sles | ( | bool | use_field_id, |
void cs_equation_param_set_saturne_sles | ( | bool | use_field_id, |
void cs_param_sles_copy_from | ( | cs_param_sles_t * | src, |
cs_param_sles_t * | dst | ||
[in] | src | reference cs_param_sles_t structure to copy |
[in,out] | dst | copy of the reference at exit |
cs_param_sles_t* cs_param_sles_create | ( | int | field_id, |
const char * | system_name | ||
[in] | field_id | id related to to the variable field or -1 |
[in] | system_name | name of the system to solve or NULL |
void cs_param_sles_free | ( | cs_param_sles_t ** | p_slesp | ) |
[in,out] | slesp | pointer to a structure to free |
void cs_param_sles_log | ( | cs_param_sles_t * | slesp | ) |
[in] | slesp | pointer to a cs_param_sles_log |
int cs_param_sles_set | ( | bool | use_field_id, |
[in] | use_field_id | if false use system name to define a SLES |
