cs_mesh.c File Reference
#include <limits.h>
#include "fvm_io_num.h"
#include "fvm_periodicity.h"
#include "fvm_selector.h"
#include "cs_halo.h"
#include "cs_halo_perio.h"
#include "cs_interface.h"
#include "cs_mesh_halo.h"
#include "cs_numbering.h"
#include "cs_order.h"
#include "cs_timer.h"
+ Include dependency graph for cs_mesh.c:
void synsca (cs_real_t var[])
void synsce (cs_real_t var[])
void synvec (cs_real_t var1[], cs_real_t var2[], cs_real_t var3[])
void synvin (cs_real_t var[])
void synvie (cs_real_t var[])
void synten (cs_real_t var11[], cs_real_t var12[], cs_real_t var13[], cs_real_t var21[], cs_real_t var22[], cs_real_t var23[], cs_real_t var31[], cs_real_t var32[], cs_real_t var33[])
void syntin (cs_real_t var[])
void syntis (cs_real_t var[])
cs_mesh_tcs_mesh_create (void)
cs_mesh_tcs_mesh_destroy (cs_mesh_t *mesh)
cs_gnum_t cs_mesh_compact_gnum (cs_lnum_t n_elts, cs_gnum_t *elt_gnum)
void cs_mesh_free_rebuildable (cs_mesh_t *mesh, bool free_halos)
void cs_mesh_discard_free_faces (cs_mesh_t *mesh)
void cs_mesh_discard_free_vertices (cs_mesh_t *mesh)
void cs_mesh_g_face_vertices_sizes (const cs_mesh_t *mesh, cs_gnum_t *g_i_face_vertices_size, cs_gnum_t *g_b_face_vertices_size)
void cs_mesh_update_b_cells (cs_mesh_t *mesh)
void cs_mesh_update_auxiliary (cs_mesh_t *mesh)
void cs_mesh_init_halo (cs_mesh_t *mesh, cs_mesh_builder_t *mb, cs_halo_type_t halo_type)
cs_gnum_t cs_mesh_n_g_ghost_cells (cs_mesh_t *mesh)
void cs_mesh_clean_families (cs_mesh_t *mesh)
fvm_group_class_set_tcs_mesh_create_group_classes (cs_mesh_t *mesh)
void cs_mesh_init_group_classes (cs_mesh_t *mesh)
void cs_mesh_init_selectors (void)
void cs_mesh_update_selectors (cs_mesh_t *mesh)
void cs_mesh_sync_var_scal (cs_real_t *var)
void cs_mesh_sync_var_scal_ext (cs_real_t *var)
void cs_mesh_sync_var_component (cs_real_t *var)
void cs_mesh_sync_var_vect_ni (cs_real_t *var1, cs_real_t *var2, cs_real_t *var3)
void cs_mesh_sync_var_vect (cs_real_t *var)
void cs_mesh_sync_var_vect_ext (cs_real_t *var)
void cs_mesh_sync_var_vect_no_rotation (cs_real_t *var)
void cs_mesh_sync_var_diag_ni (cs_real_t *var11, cs_real_t *var22, cs_real_t *var33)
void cs_mesh_sync_var_tens_ni (cs_real_t *var11, cs_real_t *var12, cs_real_t *var13, cs_real_t *var21, cs_real_t *var22, cs_real_t *var23, cs_real_t *var31, cs_real_t *var32, cs_real_t *var33)
void cs_mesh_sync_var_tens (cs_real_t *var)
void cs_mesh_sync_var_sym_tens (cs_real_t *var)
void cs_mesh_get_perio_faces (const cs_mesh_t *mesh, cs_lnum_t **n_perio_face_couples, cs_gnum_t ***perio_face_couples)
cs_gnum_tcs_mesh_get_cell_gnum (const cs_mesh_t *mesh, int blank_perio)
void cs_mesh_get_face_perio_num (const cs_mesh_t *mesh, int perio_num[])
void cs_mesh_print_info (const cs_mesh_t *mesh, const char *name)
void cs_mesh_selector_stats (cs_mesh_t *mesh)
void cs_mesh_dump (const cs_mesh_t *mesh)
◆ cs_mesh_clean_families()
void cs_mesh_clean_families ( cs_mesh_t mesh)
◆ cs_mesh_compact_gnum()
cs_gnum_t cs_mesh_compact_gnum ( cs_lnum_t  n_elts,
cs_gnum_t elt_gnum
◆ cs_mesh_create()
cs_mesh_t* cs_mesh_create ( void  )
◆ cs_mesh_create_group_classes()
fvm_group_class_set_t* cs_mesh_create_group_classes ( cs_mesh_t mesh)
◆ cs_mesh_destroy()
cs_mesh_t* cs_mesh_destroy ( cs_mesh_t mesh)
◆ cs_mesh_discard_free_faces()
void cs_mesh_discard_free_faces ( cs_mesh_t mesh)
◆ cs_mesh_discard_free_vertices()
void cs_mesh_discard_free_vertices ( cs_mesh_t mesh)
◆ cs_mesh_dump()
void cs_mesh_dump ( const cs_mesh_t mesh)
◆ cs_mesh_free_rebuildable()
void cs_mesh_free_rebuildable ( cs_mesh_t mesh,
bool  free_halos
◆ cs_mesh_g_face_vertices_sizes()
void cs_mesh_g_face_vertices_sizes ( const cs_mesh_t mesh,
cs_gnum_t g_i_face_vertices_size,
cs_gnum_t g_b_face_vertices_size
◆ cs_mesh_get_cell_gnum()
cs_gnum_t* cs_mesh_get_cell_gnum ( const cs_mesh_t mesh,
int  blank_perio
◆ cs_mesh_get_face_perio_num()
void cs_mesh_get_face_perio_num ( const cs_mesh_t mesh,
int  perio_num[]
◆ cs_mesh_get_perio_faces()
void cs_mesh_get_perio_faces ( const cs_mesh_t mesh,
cs_lnum_t **  n_perio_face_couples,
cs_gnum_t ***  perio_face_couples
◆ cs_mesh_init_group_classes()
void cs_mesh_init_group_classes ( cs_mesh_t mesh)
◆ cs_mesh_init_halo()
void cs_mesh_init_halo ( cs_mesh_t mesh,
cs_mesh_builder_t mb,
◆ cs_mesh_init_selectors()
void cs_mesh_init_selectors ( void  )
◆ cs_mesh_n_g_ghost_cells()
cs_gnum_t cs_mesh_n_g_ghost_cells ( cs_mesh_t mesh)
◆ cs_mesh_print_info()
void cs_mesh_print_info ( const cs_mesh_t mesh,
const char *  name
◆ cs_mesh_selector_stats()
void cs_mesh_selector_stats ( cs_mesh_t mesh)
◆ cs_mesh_sync_var_component()
void cs_mesh_sync_var_component ( cs_real_t var)
◆ cs_mesh_sync_var_diag_ni()
void cs_mesh_sync_var_diag_ni ( cs_real_t var11,
cs_real_t var22,
cs_real_t var33
◆ cs_mesh_sync_var_scal()
void cs_mesh_sync_var_scal ( cs_real_t var)
◆ cs_mesh_sync_var_scal_ext()
void cs_mesh_sync_var_scal_ext ( cs_real_t var)
◆ cs_mesh_sync_var_sym_tens()
void cs_mesh_sync_var_sym_tens ( cs_real_t var)
◆ cs_mesh_sync_var_tens()
void cs_mesh_sync_var_tens ( cs_real_t var)
◆ cs_mesh_sync_var_tens_ni()
void cs_mesh_sync_var_tens_ni ( cs_real_t var11,
cs_real_t var12,
cs_real_t var13,
cs_real_t var21,
cs_real_t var22,
cs_real_t var23,
cs_real_t var31,
cs_real_t var32,
cs_real_t var33
◆ cs_mesh_sync_var_vect()
void cs_mesh_sync_var_vect ( cs_real_t var)
◆ cs_mesh_sync_var_vect_ext()
void cs_mesh_sync_var_vect_ext ( cs_real_t var)
◆ cs_mesh_sync_var_vect_ni()
void cs_mesh_sync_var_vect_ni ( cs_real_t var1,
cs_real_t var2,
cs_real_t var3
◆ cs_mesh_sync_var_vect_no_rotation()
void cs_mesh_sync_var_vect_no_rotation ( cs_real_t var)
◆ cs_mesh_update_auxiliary()
void cs_mesh_update_auxiliary ( cs_mesh_t mesh)
◆ cs_mesh_update_b_cells()
void cs_mesh_update_b_cells ( cs_mesh_t mesh)
◆ cs_mesh_update_selectors()
void cs_mesh_update_selectors ( cs_mesh_t mesh)
◆ synsca()
void synsca ( cs_real_t  var[])
◆ synsce()
void synsce ( cs_real_t  var[])
◆ synten()
void synten ( cs_real_t  var11[],
cs_real_t  var12[],
cs_real_t  var13[],
cs_real_t  var21[],
cs_real_t  var22[],
cs_real_t  var23[],
cs_real_t  var31[],
cs_real_t  var32[],
cs_real_t  var33[]
◆ syntin()
void syntin ( cs_real_t  var[])
◆ syntis()
void syntis ( cs_real_t  var[])
◆ synvec()
void synvec ( cs_real_t  var1[],
cs_real_t  var2[],
cs_real_t  var3[]
◆ synvie()
void synvie ( cs_real_t  var[])
◆ synvin()
void synvin ( cs_real_t  var[])
