fvm_periodicity.h
1 #ifndef __FVM_PERIODICITY_H__
2 #define __FVM_PERIODICITY_H__
5  * Main structure for handling of periodicities
30 #include "cs_defs.h"
33  * Local headers
36 #include "fvm_defs.h"
42 /*=============================================================================
43  * Macro definitions
45
47  * Type definitions
49
50 /*----------------------------------------------------------------------------
51  * Periodicity types
52  *----------------------------------------------------------------------------*/
53
54 typedef enum {
55
60
62
63 /*============================================================================
64  * Structure definitions
65  *============================================================================*/
66
67 typedef struct _fvm_periodicity_t fvm_periodicity_t;
68
69 /*=============================================================================
70  * Static global variables
71  *============================================================================*/
72
73 /* Names of periodicity type */
74
75 extern const char *fvm_periodicity_type_name[];
76
77 /*=============================================================================
78  * Public function prototypes
79  *============================================================================*/
80
81 /*----------------------------------------------------------------------------
82  * Create an empty periodicity definition structure.
83  *
84  * To create a composed periodicity, use fvm_periodicity_compose().
85  *
86  * parameters:
87  * equiv_tolerance <-- relative tolerance for identification of
88  * possibly equivalent directions
89  *
90  * returns:
91  * pointer to the created fvm_periodicity_t structure.
92  *---------------------------------------------------------------------------*/
93
95 fvm_periodicity_create(double equiv_tolerance);
96
97 /*----------------------------------------------------------------------------
98  * Destroy an fvm_periodicity_t structure.
99  *
100  * parameters:
101  * this_periodicity <-> pointer to structure that should be destroyed
102  *
103  * returns:
104  * NULL pointer
105  *---------------------------------------------------------------------------*/
106
108 fvm_periodicity_destroy(fvm_periodicity_t *this_periodicity);
109
110 /*----------------------------------------------------------------------------
111  * Return number of transformations associated with peridocity.
112  *
113  * parameters:
114  * this_periodicity <-- pointer to the periodicity structure
115  *
116  * returns:
117  * number of periodicity transformations
118  *---------------------------------------------------------------------------*/
119
120 int
121 fvm_periodicity_get_n_transforms(const fvm_periodicity_t *this_periodicity);
122
123 /*----------------------------------------------------------------------------
124  * Return number of periodicity combination levels.
125  *
126  * Combination level is 0 for single periodicity, and 1 or 2 for
127  * combinations of periodicities (2 max in 3d).
128  *
129  * parameters:
130  * this_periodicity <-- pointer to the periodicity structure
131  *
132  * returns:
133  * number of periodicity combination levels (1 to 3)
134  *---------------------------------------------------------------------------*/
135
136 int
137 fvm_periodicity_get_n_levels(const fvm_periodicity_t *this_periodicity);
138
139 /*----------------------------------------------------------------------------
140  * Return index of periodicity transform combination levels.
141  *
142  * Combination level is 0 for single periodicity, and 1 or 2 for
143  * combinations of periodicities (2 max in 3d).
144  *
145  * parameters:
146  * this_periodicity <-- pointer to the periodicity structure
147  * tr_level_index --> start index of first transform of each level
148  * (size: 3 + 1)
149  *---------------------------------------------------------------------------*/
150
151 void
153  int tr_level_index[4]);
154
155 /*----------------------------------------------------------------------------
156  * Add a general periodicity direction.
157  *
158  * For each direction defined, two transformations are defined: direct
159  * and reverse. The id of the reverse transformation is equal to the
160  * id of the direct transformation + 1.
161  *
162  * parameters:
163  * this_periodicity <-- pointer to the periodicity structure
164  * external_num <-- external number (1 to n) associated with direction
165  * type <-- transformation type (translation or rotation)
166  * matrix <-- transformation matrix (3x4 matrix, 3 first rows
167  * of a homogeneous coordinates transformation
168  * matrix, with last row = [0 0 0 1])
169  *
170  * returns:
171  * id of the associated direct transformation.
172  *---------------------------------------------------------------------------*/
173
174 int
176  int external_num,
178  double matrix[3][4]);
179
180 /*----------------------------------------------------------------------------
181  * Add a translation-type periodicity direction.
182  *
183  * For each direction defined, two transformations are defined: direct
184  * and reverse. The id of the reverse transformation is equal to the
185  * id of the direct transformation + 1.
186  *
187  * parameters:
188  * this_periodicity <-- pointer to the periodicity structure
189  * external_num <-- external number (1 to n) associated with direction
190  * translation <-- components of translation vector (3)
191  *
192  * returns:
193  * id of the associated direct transformation.
194  *---------------------------------------------------------------------------*/
195
196 int
198  int external_num,
199  const double translation[3]);
200
201 /*----------------------------------------------------------------------------
202  * Add a rotation type periodicity direction.
203  *
204  * For each direction defined, two transformations are defined: direct
205  * and reverse. The id of the reverse transformation is equal to the
206  * id of the direct transformation + 1.
207  *
208  * parameters:
209  * this_periodicity <-- pointer to the periodicity structure
210  * external_num <-- external number (1 to n) associated with direction
211  * angle <-- rotation angle in degrees
212  * axis <-- components of rotation axis direction vector (3)
213  * invariant_point <-- components of invariant point (3)
214  *
215  * returns:
216  * id of the associated direct transformation.
217  *---------------------------------------------------------------------------*/
218
219 int
221  int external_num,
222  double angle,
223  const double axis[3],
224  const double invariant_point[3]);
225
226 /*----------------------------------------------------------------------------
227  * Return the periodicity transform id associated with an external number.
228  *
229  * parameters:
230  * this_periodicity <-- pointer to periodicity structure
231  * external_num <-- external number (1 to n) associated with direction
232  * direction <-- 1 for direct transformation, -1 for reverse
233  *
234  * returns:
235  * transformation id (0 to n-1), or -1 if not found.
236  *---------------------------------------------------------------------------*/
237
238 int
240  int external_num,
241  int direction);
242
243 /*----------------------------------------------------------------------------
244  * Return a periodicity transformation's type.
245  *
246  * parameters:
247  * this_periodicity <-- pointer to periodicity structure
248  * tr_id <-- id of transformation we are interested in
249  *
250  * returns:
251  * periodicity transform's type
252  *---------------------------------------------------------------------------*/
253
255 fvm_periodicity_get_type(const fvm_periodicity_t *this_periodicity,
256  int tr_id);
257
258 /*----------------------------------------------------------------------------
259  * Return the periodicity transform reverse's id.
260  *
261  * parameters:
262  * this_periodicity <-- pointer to periodicity structure
263  * tr_id <-- id of transformation we are interested in
264  *
265  * returns:
266  * reverse transformation id (0 to n-1), or -1 if not found.
267  *---------------------------------------------------------------------------*/
268
269 int
270 fvm_periodicity_get_reverse_id(const fvm_periodicity_t *this_periodicity,
271  int tr_id);
272
273 /*----------------------------------------------------------------------------
274  * Return a periodicity transformation's parents.
275  *
276  * A standard transformation has combination level 0, and no parents.
277  * Transformations built from combination of 2 parents have combination
278  * level 1, and those built from the combination of 3 parents have
279  * combination level 2.
280  *
281  * Level 2 transformations are built from a combination of a level 0
282  * transformation with a level 1 transformation (itself a combination of
283  * 2 level 0 transformations).
284  *
285  * parameters:
286  * this_periodicity <-- pointer to periodicity structure
287  * tr_id <-- id of transformation we are interested in
288  * parent_ids --> parent ids, or -1 (size: 2)
289  *---------------------------------------------------------------------------*/
290
291 void
292 fvm_periodicity_get_parent_ids(const fvm_periodicity_t *this_periodicity,
293  int tr_id,
294  int parent_ids[2]);
295
296 /*----------------------------------------------------------------------------
297  * Return a periodicity transformation's component ids.
298  *
299  * A standard transformation has combination level 0, and no parents.
300  * Transformations built from combination of 2 parents have combination
301  * level 1, and those built from the combination of 3 parents have
302  * combination level 2.
303  *
304  * Level 2 transformations are built from a combination of a level 0
305  * transformation with a level 1 transformation (itself a combination of
306  * 2 level 0 transformations). Component ids allow direct access to the 3
307  * corresponding level 0 combinations.
308  *
309  * parameters:
310  * this_periodicity <-- pointer to periodicity structure
311  * tr_id <-- id of transformation we are interested in
312  * component_ids --> component ids, or -1 (size: 3)
313  *---------------------------------------------------------------------------*/
314
315 void
316 fvm_periodicity_get_components(const fvm_periodicity_t *this_periodicity,
317  int tr_id,
318  int component_ids[3]);
319
320 /*----------------------------------------------------------------------------
321  * Return a periodicity transformation's first equivalent transform id.
322  *
323  * If multiple transformations are equivalent, each will point to
324  * the previous equivalent transformation, defining a reversed linked list.
325  *
326  * parameters:
327  * this_periodicity <-- pointer to periodicity structure
328  * tr_id <-- id of transformation we are interested in
329  *
330  * returns:
331  * id of first equivalent transformation
332  *---------------------------------------------------------------------------*/
333
334 int
335 fvm_periodicity_get_equiv_id(const fvm_periodicity_t *this_periodicity,
336  int tr_id);
337
338 /*----------------------------------------------------------------------------
339  * Return a periodicity transformation's matrix.
340  *
341  * parameters:
342  * this_periodicity <-- pointer to periodicity structure
343  * tr_id <-- id of transformation we are interested in
344  * matrix --> coefficients of transformation matrix
345  *
346  * returns:
347  * periodicity transform's matrix
348  *---------------------------------------------------------------------------*/
349
350 void
351 fvm_periodicity_get_matrix(const fvm_periodicity_t *this_periodicity,
352  int tr_id,
353  double matrix[3][4]);
354
355 /*----------------------------------------------------------------------------
356  * Complete periodicity information with combined transformations.
357  *
358  * This function should only be called once, after all base periodicity
359  * transforms have been defined. It returns immediately if combined
360  * transforms are already defined.
361  *
362  * parameters:
363  * this_periodicity <-> pointer to the periodicity structure
364  * abort_on_error <-- 0: non-commuting combinations are discarded
365  * 1: abort in presence of non-commuting combinations
366  *---------------------------------------------------------------------------*/
367
368 void
370  int abort_on_error);
371
372 /*----------------------------------------------------------------------------
373  * Dump fvm_periodicity_t structure
374  *
375  * parameters:
376  * this_periodicity <-- pointer to the periodicity structure
377  *---------------------------------------------------------------------------*/
378
379 void
380 fvm_periodicity_dump(const fvm_periodicity_t *this_periodicity);
381
382 /*----------------------------------------------------------------------------*/
383
385
386 #endif /* __FVM_PERIODICITY_H__ */
int fvm_periodicity_add_rotation(fvm_periodicity_t *this_periodicity, int external_num, double angle, const double axis[3], const double invariant_point[3])
Definition: fvm_periodicity.c:819
void fvm_periodicity_get_matrix(const fvm_periodicity_t *this_periodicity, int tr_id, double matrix[3][4])
Definition: fvm_periodicity.c:1155
fvm_periodicity_type_t
Definition: fvm_periodicity.h:54
int fvm_periodicity_get_n_transforms(const fvm_periodicity_t *this_periodicity)
Definition: fvm_periodicity.c:593
int fvm_periodicity_get_n_levels(const fvm_periodicity_t *this_periodicity)
Definition: fvm_periodicity.c:617
Definition: cs_defs.h:495
void fvm_periodicity_get_tr_level_idx(const fvm_periodicity_t *this_periodicity, int tr_level_index[4])
Definition: fvm_periodicity.c:640
int fvm_periodicity_get_reverse_id(const fvm_periodicity_t *this_periodicity, int tr_id)
Definition: fvm_periodicity.c:979
int fvm_periodicity_get_transform_id(const fvm_periodicity_t *this_periodicity, int external_num, int direction)
Definition: fvm_periodicity.c:916
Definition: fvm_periodicity.h:58
Definition: fvm_periodicity.h:59
Definition: fvm_periodicity.h:57
Definition: cs_matrix_building.c:112
void fvm_periodicity_get_components(const fvm_periodicity_t *this_periodicity, int tr_id, int component_ids[3])
Definition: fvm_periodicity.c:1061
Definition: fvm_periodicity.h:56
fvm_periodicity_t * fvm_periodicity_destroy(fvm_periodicity_t *this_periodicity)
Definition: fvm_periodicity.c:565
fvm_periodicity_type_t fvm_periodicity_get_type(const fvm_periodicity_t *this_periodicity, int tr_id)
Definition: fvm_periodicity.c:955
Definition: fvm_periodicity.h:67
int fvm_periodicity_get_equiv_id(const fvm_periodicity_t *this_periodicity, int tr_id)
Definition: fvm_periodicity.c:1127
void fvm_periodicity_combine(fvm_periodicity_t *this_periodicity, int abort_on_error)
Definition: fvm_periodicity.c:1195
Definition: cs_defs.h:496
int fvm_periodicity_add_by_matrix(fvm_periodicity_t *this_periodicity, int external_num, fvm_periodicity_type_t type, double matrix[3][4])
Definition: fvm_periodicity.c:674
fvm_periodicity_t * fvm_periodicity_create(double equiv_tolerance)
Definition: fvm_periodicity.c:534
void fvm_periodicity_dump(const fvm_periodicity_t *this_periodicity)
Definition: fvm_periodicity.c:1332
void fvm_periodicity_get_parent_ids(const fvm_periodicity_t *this_periodicity, int tr_id, int parent_ids[2])
Definition: fvm_periodicity.c:1013
int fvm_periodicity_add_translation(fvm_periodicity_t *this_periodicity, int external_num, const double translation[3])
Definition: fvm_periodicity.c:782
const char * fvm_periodicity_type_name[]
