#include "cs_defs.h"#include <stdio.h>#include <stdlib.h>#include <math.h>#include <string.h>#include <stdarg.h>#include <fcntl.h>#include <unistd.h>#include <assert.h>#include "bft_mem.h"#include "bft_error.h"#include "bft_printf.h"#include "cs_base.h"#include "cs_parameters.h"#include "cs_tree.h"#include "cs_tree_xml.h"#include "cs_gui_util.h"
Include dependency graph for cs_gui_util.c:Functions | |
| int | cs_gui_load_file (const char *filename) |
| Load the XML file in memory. More... | |
| void | cs_gui_check_version (void) |
| Check the XML file version. More... | |
| int | cs_gui_characters_number (int num) |
| int | cs_gui_strcmp (const char *s1, const char *s2) |
| int | cs_gui_is_equal_real (cs_real_t v1, cs_real_t v2) |
| void | cs_gui_node_get_int (cs_tree_node_t *node, int *value) |
| Update an integer value based on a tree node. More... | |
| void | cs_gui_node_get_real (cs_tree_node_t *node, cs_real_t *value) |
| Update an real value based on a tree node. More... | |
| void | cs_gui_node_get_status_int (cs_tree_node_t *node, int *status) |
| Update an integer-valued status value based on a node's status tag. More... | |
| void | cs_gui_node_get_status_bool (cs_tree_node_t *node, bool *status) |
| Update an bool-valued status value based on a node's status tag. More... | |
| const char * | cs_gui_node_get_tag (cs_tree_node_t *node, const char *tag_name) |
| Return a string value associated with a "tag" child node and whose presence should be guaranteed. More... | |
| void | cs_gui_node_get_child_int (cs_tree_node_t *node, const char *child_name, int *value) |
| Update an integer value based on a tree's child node. More... | |
| void | cs_gui_node_get_child_real (cs_tree_node_t *node, const char *child_name, cs_real_t *value) |
| void | cs_gui_node_get_child_status_int (cs_tree_node_t *node, const char *child_name, int *status) |
| Update an integer-valued status value based on a node child's status tag. More... | |
| void | cs_gui_node_get_child_status_bool (cs_tree_node_t *node, const char *child_name, bool *status) |
| Update a bool-valued status value based on a node child's status tag. More... | |
| void | cs_gui_add_mei_time (double t) |
| double | cs_gui_get_mei_times (void) |
| void cs_gui_add_mei_time | ( | double | t | ) |
| int cs_gui_characters_number | ( | int | num | ) |
| void cs_gui_check_version | ( | void | ) |
| double cs_gui_get_mei_times | ( | void | ) |
| int cs_gui_load_file | ( | const char * | filename | ) |
| [in] | filename | XML file containing the parameters |
| void cs_gui_node_get_child_int | ( | cs_tree_node_t * | node, |
| const char * | child_name, | ||
| int * | value | ||
If no node is present, the initial value is unchanged. If the node is present but the value missing, an error is returned.
| [in] | node | node whose value is queried |
| [in] | child_name | name of child node |
| [in,out] | value | queried value |
| void cs_gui_node_get_child_real | ( | cs_tree_node_t * | node, |
| cs_real_t * | value | ||
| void cs_gui_node_get_child_status_bool | ( | cs_tree_node_t * | node, |
| bool * | status | ||
The status is defined in a string-valued child (tag) node. If no such child and tag is present, the initial status is unchanged.
| [in,out] | status | queried value |
| void cs_gui_node_get_child_status_int | ( | cs_tree_node_t * | node, |
| int * | status | ||
| void cs_gui_node_get_int | ( | cs_tree_node_t * | node, |
| int * | value | ||
| void cs_gui_node_get_real | ( | cs_tree_node_t * | node, |
| void cs_gui_node_get_status_bool | ( | cs_tree_node_t * | node, |
The status is defined in a string-valued child (tag) node. If no such tag is present, the initial status is unchanged.
| [in] | node | node whose status is queried |
| [in,out] | status | status value (0 or 1) |
| void cs_gui_node_get_status_int | ( | cs_tree_node_t * | node, |
| int * | status | ||
| const char* cs_gui_node_get_tag | ( | cs_tree_node_t * | node, |
| const char * | tag_name | ||
If the matching child node is not present, an error is produced
| [in] | node | tree node which should have a "tag" child |
| [in] | tag_name | name of tag child node |
| int cs_gui_strcmp | ( | const char * | s1, |
| const char * | s2 | ||
