#include <stdbool.h>#include "cs_boundary.h"#include "cs_cdo_connect.h"#include "cs_cdo_quantities.h"#include "cs_mesh.h"#include "cs_mesh_quantities.h"#include "cs_time_step.h"#include "cs_timer.h"#include "cs_xdef.h"
Include dependency graph for cs_domain.h:Go to the source code of this file.
| struct | cs_domain_cdo_context_t |
| High-level metadata for handling CDO/HHO schemes. More... | |
| struct | cs_domain_t |
| Structure storing the main features of the computational domain and pointers to the main geometrical structures. More... | |
Macros | |
| #define | CS_DOMAIN_CDO_MODE_OFF -1 /* CDO schemes are not used */ |
| #define | CS_DOMAIN_CDO_MODE_WITH_FV 1 /* CDO and legacy FV schemes are used */ |
| #define | CS_DOMAIN_CDO_MODE_ONLY 2 /* CDO schemes are exclusively used */ |
| cs_domain_t * | cs_domain_create (void) |
| Create and initialize by default a cs_domain_t structure. More... | |
| void | cs_domain_free (cs_domain_t **p_domain) |
| Free a cs_domain_t structure. More... | |
| void | cs_domain_set_cdo_mode (cs_domain_t *domain, int mode) |
| Set the global variable storing the mode of activation to apply to CDO/HHO schemes. More... | |
| int | cs_domain_get_cdo_mode (const cs_domain_t *domain) |
| Get the mode of activation for the CDO/HHO schemes. More... | |
| bool | cs_domain_needs_iteration (cs_domain_t *domain) |
| Check if one needs to continue iterations in time. More... | |
| bool | cs_domain_needs_log (const cs_domain_t *domain) |
| Check if an output is requested according to the domain setting. More... | |
| void | cs_domain_increment_time (cs_domain_t *domain) |
| Update time step after one temporal iteration. More... | |
| void | cs_domain_cdo_log (const cs_domain_t *domain) |
| Print a welcome message indicating which mode of CDO is activated. More... | |
| cs_domain_t * | cs_glob_domain |
| #define CS_DOMAIN_CDO_MODE_OFF -1 /* CDO schemes are not used */ |
| #define CS_DOMAIN_CDO_MODE_ONLY 2 /* CDO schemes are exclusively used */ |
| #define CS_DOMAIN_CDO_MODE_WITH_FV 1 /* CDO and legacy FV schemes are used */ |
| void cs_domain_cdo_log | ( | const cs_domain_t * | domain | ) |
| [in] | domain | pointer to a cs_domain_t structure |
| cs_domain_t* cs_domain_create | ( | void | ) |
| void cs_domain_free | ( | cs_domain_t ** | p_domain | ) |
| [in,out] | p_domain | pointer of pointer to a cs_domain_t structure |
| int cs_domain_get_cdo_mode | ( | const cs_domain_t * | domain | ) |
| void cs_domain_increment_time | ( | cs_domain_t * | domain | ) |
| bool cs_domain_needs_iteration | ( | cs_domain_t * | domain | ) |
| bool cs_domain_needs_log | ( | const cs_domain_t * | domain | ) |
| void cs_domain_set_cdo_mode | ( | cs_domain_t * | domain, |
| int | mode | ||
| [in] | mode | type of activation for the CDO/HHO module |
| cs_domain_t* cs_glob_domain |
