1 #ifndef __CS_BOUNDARY_H__ 2 #define __CS_BOUNDARY_H__ 45 #define CS_BOUNDARY_PRESSURE_NO_RESCALING 1 46 #define CS_BOUNDARY_PRESSURE_RESCALING 0 49 #define CS_BOUNDARY_WALLS_NAME "auto:wall" 51 #define CS_BOUNDARY_UNDEFINED 0 260 const char *zone_name);
int cs_boundary_id_by_zone_id(const cs_boundary_t *boundaries, int z_id)
Retrieve the related id associated to a boundary from its zone id.
Definition: cs_boundary.c:396
Definition: cs_boundary.h:104
int cs_boundary_type_t
Definition: cs_boundary.h:69
int cs_boundary_need_pressure_rescaling(cs_lnum_t n_b_faces, const cs_boundary_type_t bf_type[])
Check if one needs to perform a pressure rescaling (in case of a Dirichlet on the velocity for the wh...
Definition: cs_boundary.c:609
cs_boundary_ale_subtype_bits_t
Definition: cs_boundary.h:138
Definition: cs_boundary.h:113
int n_boundaries
Definition: cs_boundary.h:160
Definition: cs_defs.h:495
Definition: cs_boundary.h:144
Definition: cs_boundary.h:62
Definition: cs_boundary.h:125
cs_boundary_category_t category
Definition: cs_boundary.h:157
Definition: cs_boundary.h:95
bool cs_boundary_has_type(const cs_boundary_t *boundaries, int type_flag)
Check if a boundary with a given flag is present.
Definition: cs_boundary.c:370
Definition: cs_boundary.h:131
cs_boundary_type_t default_type
Definition: cs_boundary.h:158
Structure storing information related to the "physical" boundaries associated with the computational ...
Definition: cs_boundary.h:155
cs_boundary_flow_subtype_bits_t
Definition: cs_boundary.h:74
cs_boundary_type_t * types
Definition: cs_boundary.h:161
Definition: cs_boundary.h:119
Definition: cs_boundary.h:122
void cs_boundary_set_default(cs_boundary_t *boundaries, cs_boundary_type_t type)
Set the default boundary related to the given cs_boundary_t structure.
Definition: cs_boundary.c:429
Definition: cs_boundary.h:116
Definition: cs_boundary.h:128
void cs_boundary_def_wall_zones(cs_boundary_t *boundaries)
Add a new zone gathering all CS_BOUNDARY_WALL type zones.
Definition: cs_boundary.c:574
cs_boundary_t * cs_glob_boundaries
cs_boundary_t * cs_boundary_create(cs_boundary_category_t category, cs_boundary_type_t default_type)
Create a default boundary structure for the computational domain.
Definition: cs_boundary.c:456
Definition: cs_boundary.h:146
Definition: cs_boundary.h:142
Definition: cs_boundary.h:110
void cs_boundary_build_type_array(const cs_boundary_t *boundaries, cs_lnum_t n_b_faces, cs_boundary_type_t bf_type[])
Build an array on boundary faces which specifies the boundary type for each face. ...
Definition: cs_boundary.c:544
Definition: cs_boundary.h:140
Definition: cs_boundary.h:107
Definition: cs_boundary.h:141
Definition: cs_boundary.h:89
Definition: cs_boundary.h:143
Definition: cs_boundary.h:80
Definition: cs_defs.h:301
Definition: cs_boundary.h:98
Definition: cs_boundary.h:61
Definition: cs_boundary.h:86
Definition: cs_defs.h:496
Definition: cs_boundary.h:145
void cs_boundary_free(cs_boundary_t **p_boundaries)
Free all metadate related to the domain boundaries.
Definition: cs_boundary.c:481
void cs_boundary_add(cs_boundary_t *bdy, cs_boundary_type_t type, const char *zone_name)
Add a new boundary type for a given boundary zone.
Definition: cs_boundary.c:505
void cs_boundary_log_setup(const cs_boundary_t *bdy)
Summarize the setup of the boundary of the computational domain.
Definition: cs_boundary.c:682
Definition: cs_boundary.h:63
Definition: cs_boundary.h:83
void cs_boundary_get_type_descr(const cs_boundary_t *bdy, cs_boundary_type_t b_type, int descr_len_max, char descr[])
Build a boundary type description.
Definition: cs_boundary.c:649
Definition: cs_boundary.h:59
Definition: cs_boundary.h:101
int * zone_ids
Definition: cs_boundary.h:162
