62 #if defined(DEBUG) && !defined(NDEBUG) 73 cs_dbg_check_hmg_dirichlet_cw(
const char *fname,
76 for (
short int i = 0; i < csys->
n_dofs; i++) {
80 " %s: Invalid value for a homogeneous Dirichlet condition",
123 cs_dbg_array_fprintf(FILE *fp,
145 cs_dbg_fprintf_system(
const char *eqname,
164 cs_dbg_darray_to_listing(
const char *header,
181 cs_dbg_iarray_to_listing(
const char *header,
196 cs_dbg_dump_local_scalar_msr_matrix(
const char *name,
215 cs_dbg_dump_linear_system(
const char *eqname,
#define CS_CDO_BC_HMG_DIRICHLET
Definition: cs_cdo_bc.h:66
Definition: cs_equation_param.h:202
Definition: cs_defs.h:495
double * dir_values
Definition: cs_cdo_local.h:129
Set of local quantities and connectivities related to a mesh cell This is a key structure for all cel...
Definition: cs_cdo_local.h:159
cs_flag_t * dof_flag
Definition: cs_cdo_local.h:113
Definition: bft_error.c:193
Definition: cs_defs.h:307
Definition: cs_matrix_building.c:112
Definition: cs_cdo_local.h:107
Definition: cs_matrix.h:94
int n_dofs
Definition: cs_cdo_local.h:111
Definition: cs_defs.h:301
Definition: cs_defs.h:496
Structure and routines handling the specific settings related to a cs_equation_t structure.
double precision, save b
