#include "cs_defs.h"#include <assert.h>#include <errno.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include "bft_mem.h"#include "bft_mem_usage.h"#include "bft_error.h"#include "bft_printf.h"#include "cs_base.h"#include "cs_assert.h"#include "cs_block_dist.h"#include "cs_crystal_router.h"#include "cs_log.h"#include "cs_order.h"#include "cs_rank_neighbors.h"#include "cs_timer.h"#include "cs_all_to_all.h"
Include dependency graph for cs_all_to_all.c:Functions | |
| cs_all_to_all_t * | cs_all_to_all_create (size_t n_elts, int flags, const cs_lnum_t *dest_id, const int dest_rank[], MPI_Comm comm) |
| Create an all-to-all distributor based on destination rank. More... | |
| cs_all_to_all_t * | cs_all_to_all_create_from_block (size_t n_elts, int flags, const cs_gnum_t *src_gnum, cs_block_dist_info_t bi, MPI_Comm comm) |
| Create an all-to-all distributor for elements whose destination rank is determined from global numbers and block distribution information. More... | |
| void | cs_all_to_all_destroy (cs_all_to_all_t **d) |
| Destroy an all-to-all distributor. More... | |
| void | cs_all_to_all_transfer_dest_rank (cs_all_to_all_t *d, int **dest_rank) |
| Transfer ownership of destination rank to an all-to-all distributor. More... | |
| void | cs_all_to_all_transfer_dest_id (cs_all_to_all_t *d, cs_lnum_t **dest_id) |
| Transfer ownership of destination ids to an all-to-all distributor. More... | |
| cs_lnum_t | cs_all_to_all_n_elts_dest (cs_all_to_all_t *d) |
| Get number of elements associated with all-to-all distributor. More... | |
| void * | cs_all_to_all_copy_array (cs_all_to_all_t *d, cs_datatype_t datatype, int stride, bool reverse, const void *src_data, void *dest_data) |
| Communicate array data using all-to-all distributor. More... | |
| cs_lnum_t * | cs_all_to_all_copy_index (cs_all_to_all_t *d, bool reverse, const cs_lnum_t *src_index, cs_lnum_t *dest_index) |
| Communicate local index using all-to-all distributor. More... | |
| void * | cs_all_to_all_copy_indexed (cs_all_to_all_t *d, cs_datatype_t datatype, bool reverse, const cs_lnum_t *src_index, const void *src_data, const cs_lnum_t *dest_index, void *dest_data) |
| int * | cs_all_to_all_get_src_rank (cs_all_to_all_t *d) |
| Get array of source element ranks associated with an all-to-all distributor. More... | |
| cs_all_to_all_type_t | cs_all_to_all_get_type (void) |
| Get current type of all-to-all distributor algorithm choice. More... | |
| void | cs_all_to_all_get_hybrid_parameters (cs_rank_neighbors_exchange_t *rne_type) |
| Get current type of hybrid all-to-all distributor parameters. More... | |
| void | cs_all_to_all_set_hybrid_parameters (cs_rank_neighbors_exchange_t rne_type) |
| Set current type of all-to-all distributor algorithm choice. More... | |
| void | cs_all_to_all_set_type (cs_all_to_all_type_t t) |
| void | cs_all_to_all_log_finalize (void) |
| Log performance information relative to instrumented all-to-all distribution. More... | |
All-to-all parallel data exchange.
| void* cs_all_to_all_copy_array | ( | cs_all_to_all_t * | d, |
| int | stride, | ||
| bool | reverse, | ||
| const void * | src_data, | ||
| void * | dest_data | ||
If a destination buffer is provided, it should be of sufficient size for the number of elements returned by cs_all_to_all_n_elts_dest (multiplied by stride and datatype size).
If used in reverse mode, data is still communicated from src_data to dest_buffer or an internal buffer, but communication direction (i.e. source and destination ranks) are reversed.
This is obviously a collective operation, and all ranks must provide the same datatype, stride, and reverse values.
| [in,out] | d | pointer to associated all-to-all distributor |
| [in] | datatype | type of data considered |
| [in] | stride | number of values per entity (interlaced), |
| [in] | reverse | if true, communicate in reverse direction |
| [in] | src_data | source data |
| [out] | dest_data | pointer to destination data, or NULL |
| cs_lnum_t* cs_all_to_all_copy_index | ( | cs_all_to_all_t * | d, |
| const cs_lnum_t * | src_index, | ||
| cs_lnum_t * | dest_index | ||
If a destination buffer is provided, it should be of sufficient size for the number of elements returned by cs_all_to_all_n_elts_dest.
If used in reverse mode, data is still communicated from src_index to dest_index or an internal buffer, but communication direction (i.e. source and destination ranks) are reversed.
This is obviously a collective operation, and all ranks must provide the same value for the reverse parameter.
| [in] | src_index | source index |
| [out] | dest_index | pointer to destination index, or NULL |
| void* cs_all_to_all_copy_indexed | ( | cs_all_to_all_t * | d, |
| const cs_lnum_t * | dest_index, | ||
If a destination buffer is provided, it should be of sufficient size for the number of elements indicated by dest_index[cs_all_to_all_n_elts_dest(d)];
| [in] | dest_index | destination index |
| cs_all_to_all_t* cs_all_to_all_create | ( | size_t | n_elts, |
| int | flags, | ||
| const cs_lnum_t * | dest_id, | ||
| const int | dest_rank[], | ||
| MPI_Comm | comm | ||
This is a collective operation on communicator comm.
If the flags bit mask matches CS_ALL_TO_ALL_USE_DEST_ID, data exchanged will be ordered by the array passed to the dest_id argument. For n total values received on a rank (as given by cs_all_to_all_n_elts_dest), those destination ids must be in the range [0, n[.
If the flags bit mask matches CS_ALL_TO_ALL_ORDER_BY_SRC_RANK, data exchanged will be ordered by source rank (this is incompatible with CS_ALL_TO_ALL_USE_DEST_ID.
dest_rank and dest_id arrays are only referenced by the distributor, not copied, and must remain available throughout the distributor's lifetime. They may be fully transferred to the structure if not needed elsewhere using the cs_all_to_all_transfer_dest_rank and cs_all_to_all_transfer_dest_id functions.| [in] | n_elts | number of elements |
| [in] | flags | sum of ordering and metadata flag constants |
| [in] | dest_id | element destination id (required if flags contain CS_ALL_TO_ALL_USE_DEST_ID), or NULL |
| [in] | dest_rank | destination rank for each element |
| [in] | comm | associated MPI communicator |
| cs_all_to_all_t* cs_all_to_all_create_from_block | ( | size_t | n_elts, |
| int | flags, | ||
| const cs_gnum_t * | src_gnum, | ||
| cs_block_dist_info_t | bi, | ||
If the flags bit mask matches CS_ALL_TO_ALL_USE_DEST_ID, data exchanged will be ordered by global element number.
| [in] | src_gnum | global source element numbers |
| [in] | bi | destination block distribution info |
| void cs_all_to_all_destroy | ( | cs_all_to_all_t ** | d | ) |
| void cs_all_to_all_get_hybrid_parameters | ( | cs_rank_neighbors_exchange_t * | rne_type | ) |
| [out] | rne_type | type of metadata exchange algorithm, or NULL |
| int* cs_all_to_all_get_src_rank | ( | cs_all_to_all_t * | d | ) |
This function should be called only after cs_all_to_all_copy_array, and allocates and returns an array of source element ranks matching the exchanged data elements.
It should also be called only if the distributor creation flags match CS_ALL_TO_ALL_NEED_SRC_RANK or CS_ALL_TO_ALL_ORDER_BY_SRC_RANK.
The returned data is owned by the caller, who is responsible for freeing it when no longer needed.
If source ranks are not available (depending on the distributor creation function and options), the matching pointer will be set to NULL.
| [in] | d | pointer to associated all-to-all distributor |
| cs_all_to_all_type_t cs_all_to_all_get_type | ( | void | ) |
| void cs_all_to_all_log_finalize | ( | void | ) |
| cs_lnum_t cs_all_to_all_n_elts_dest | ( | cs_all_to_all_t * | d | ) |
If no exchange has been done yet (depending on the communication protocol), metadata will be exchanged by this call, so it is a collective operation.
| void cs_all_to_all_set_hybrid_parameters | ( | cs_rank_neighbors_exchange_t | rne_type | ) |
| [in] | rne_type | type of metadata exchange algorithm |
| void cs_all_to_all_set_type | ( | cs_all_to_all_type_t | t | ) |
| t | type of all-to-all distributor algorithm choice to select |
| void cs_all_to_all_transfer_dest_id | ( | cs_all_to_all_t * | d, |
| cs_lnum_t ** | dest_id | ||
The dest_id array should be the same as the one used for the creation of the distributor.
| [in,out] | dest_id | pointer to element destination id |
| void cs_all_to_all_transfer_dest_rank | ( | cs_all_to_all_t * | d, |
| int ** | dest_rank | ||
The dest_rank array should be the same as the one used for the creation of the distributor.
| [in,out] | dest_rank | pointer to element destination rank |
