cs_all_to_all.h File Reference
#include <mpi.h>
#include "cs_block_dist.h"
#include "cs_rank_neighbors.h"
+ Include dependency graph for cs_all_to_all.h:
Macros
#define CS_ALL_TO_ALL_USE_DEST_ID   (1 << 0)
#define CS_ALL_TO_ALL_ORDER_BY_SRC_RANK   (1 << 1)
#define CS_ALL_TO_ALL_NO_REVERSE   (1 << 2)
#define CS_ALL_TO_ALL_NEED_SRC_RANK   (1 << 3)
Typedefs
typedef struct _cs_all_to_all_t cs_all_to_all_t
Enumerations
enum  cs_all_to_all_type_t { CS_ALL_TO_ALL_MPI_DEFAULT, CS_ALL_TO_ALL_HYBRID, CS_ALL_TO_ALL_CRYSTAL_ROUTER }
 All-to-all algorithm selection. More...
cs_all_to_all_tcs_all_to_all_create (size_t n_elts, int flags, const cs_lnum_t *dest_id, const int dest_rank[], MPI_Comm comm)
 Create an all-to-all distributor based on destination rank. More...
cs_all_to_all_tcs_all_to_all_create_from_block (size_t n_elts, int flags, const cs_gnum_t *src_gnum, cs_block_dist_info_t bi, MPI_Comm comm)
 Create an all-to-all distributor for elements whose destination rank is determined from global numbers and block distribution information. More...
void cs_all_to_all_destroy (cs_all_to_all_t **d)
 Destroy an all-to-all distributor. More...
void cs_all_to_all_transfer_dest_rank (cs_all_to_all_t *d, int **dest_rank)
 Transfer ownership of destination rank to an all-to-all distributor. More...
void cs_all_to_all_transfer_dest_id (cs_all_to_all_t *d, cs_lnum_t **dest_id)
 Transfer ownership of destination ids to an all-to-all distributor. More...
cs_lnum_t cs_all_to_all_n_elts_dest (cs_all_to_all_t *d)
 Get number of elements associated with all-to-all distributor. More...
void * cs_all_to_all_copy_array (cs_all_to_all_t *d, cs_datatype_t datatype, int stride, bool reverse, const void *src_data, void *dest_data)
 Communicate array data using all-to-all distributor. More...
cs_lnum_tcs_all_to_all_copy_index (cs_all_to_all_t *d, bool reverse, const cs_lnum_t *src_index, cs_lnum_t *dest_index)
 Communicate local index using all-to-all distributor. More...
void * cs_all_to_all_copy_indexed (cs_all_to_all_t *d, cs_datatype_t datatype, bool reverse, const cs_lnum_t *src_index, const void *src_data, const cs_lnum_t *dest_index, void *dest_data)
int * cs_all_to_all_get_src_rank (cs_all_to_all_t *d)
 Get array of source element ranks associated with an all-to-all distributor. More...
cs_all_to_all_type_t cs_all_to_all_get_type (void)
 Get current type of all-to-all distributor algorithm choice. More...
void cs_all_to_all_set_type (cs_all_to_all_type_t t)
 Set current type of all-to-all distributor algorithm choice. More...
void cs_all_to_all_get_hybrid_parameters (cs_rank_neighbors_exchange_t *rne_type)
 Get current type of hybrid all-to-all distributor parameters. More...
void cs_all_to_all_set_hybrid_parameters (cs_rank_neighbors_exchange_t rne_type)
void cs_all_to_all_log_finalize (void)
 Log performance information relative to instrumented all-to-all distribution. More...
◆ CS_ALL_TO_ALL_NEED_SRC_RANK
◆ CS_ALL_TO_ALL_NO_REVERSE
◆ CS_ALL_TO_ALL_ORDER_BY_SRC_RANK
◆ CS_ALL_TO_ALL_USE_DEST_ID
All-to-all distributor ordering and metadata flags.
Typedef Documentation
◆ cs_all_to_all_t
Opaque all-to-all distribution structure
◆ cs_all_to_all_type_t
Enumerator
Use MPI_Alltoall and MPI_Alltoallv sequences
Use crystal router algorithm
Flags are defined as a sum (bitwise or) of constants, which may include CS_ALL_TO_ALL_USE_DEST_ID, CS_ALL_TO_ALL_ORDER_BY_SRC_RANK, CS_ALL_TO_ALL_NO_REVERSE, and CS_ALL_TO_ALL_NEED_SRC_RANK.
◆ cs_all_to_all_copy_array()
void* cs_all_to_all_copy_array ( cs_all_to_all_t d,
int  stride,
bool  reverse,
const void *  src_data,
void *  dest_data
If a destination buffer is provided, it should be of sufficient size for the number of elements returned by cs_all_to_all_n_elts_dest (multiplied by stride and datatype size).
If used in reverse mode, data is still communicated from src_data to dest_buffer or an internal buffer, but communication direction (i.e. source and destination ranks) are reversed.
This is obviously a collective operation, and all ranks must provide the same datatype, stride, and reverse values.
[in,out]dpointer to associated all-to-all distributor
[in]datatypetype of data considered
[in]stridenumber of values per entity (interlaced),
[in]reverseif true, communicate in reverse direction
[in]src_datasource data
[out]dest_datapointer to destination data, or NULL
pointer to destination data (dest_buffer if non-NULL)
◆ cs_all_to_all_copy_index()
cs_lnum_t* cs_all_to_all_copy_index ( cs_all_to_all_t d,
bool  reverse,
const cs_lnum_t src_index,
cs_lnum_t dest_index
If a destination buffer is provided, it should be of sufficient size for the number of elements returned by cs_all_to_all_n_elts_dest.
If used in reverse mode, data is still communicated from src_index to dest_index or an internal buffer, but communication direction (i.e. source and destination ranks) are reversed.
This is obviously a collective operation, and all ranks must provide the same value for the reverse parameter.
[in]src_indexsource index
[out]dest_indexpointer to destination index, or NULL
◆ cs_all_to_all_copy_indexed()
void* cs_all_to_all_copy_indexed ( cs_all_to_all_t d,
bool  reverse,
const cs_lnum_t dest_index,
void *  dest_data
If a destination buffer is provided, it should be of sufficient size for the number of elements indicated by dest_index[cs_all_to_all_n_elts_dest(d)];
[in]dest_indexdestination index
◆ cs_all_to_all_create()
cs_all_to_all_t* cs_all_to_all_create ( size_t  n_elts,
int  flags,
const cs_lnum_t dest_id,
MPI_Comm  comm
This is a collective operation on communicator comm.
If the flags bit mask matches CS_ALL_TO_ALL_USE_DEST_ID, data exchanged will be ordered by the array passed to the dest_id argument. For n total values received on a rank (as given by cs_all_to_all_n_elts_dest), those destination ids must be in the range [0, n[.
If the flags bit mask matches CS_ALL_TO_ALL_ORDER_BY_SRC_RANK, data exchanged will be ordered by source rank (this is incompatible with CS_ALL_TO_ALL_USE_DEST_ID.
Attention
The dest_rank and dest_id arrays are only referenced by the distributor, not copied, and must remain available throughout the distributor's lifetime. They may be fully transferred to the structure if not needed elsewhere using the cs_all_to_all_transfer_dest_rank and cs_all_to_all_transfer_dest_id functions.
[in]n_eltsnumber of elements
[in]flagssum of ordering and metadata flag constants
[in]dest_idelement destination id (required if flags contain CS_ALL_TO_ALL_USE_DEST_ID), or NULL
[in]dest_rankdestination rank for each element
[in]commassociated MPI communicator
pointer to new all-to-all distributor
◆ cs_all_to_all_create_from_block()
cs_all_to_all_t* cs_all_to_all_create_from_block ( size_t  n_elts,
int  flags,
const cs_gnum_t src_gnum,
MPI_Comm  comm
If the flags bit mask matches CS_ALL_TO_ALL_USE_DEST_ID, data exchanged will be ordered by global element number.
[in]src_gnumglobal source element numbers
[in]bidestination block distribution info
◆ cs_all_to_all_destroy()
void cs_all_to_all_destroy ( cs_all_to_all_t **  d)
◆ cs_all_to_all_get_hybrid_parameters()
void cs_all_to_all_get_hybrid_parameters ( cs_rank_neighbors_exchange_t rne_type)
[out]rne_typetype of metadata exchange algorithm, or NULL
◆ cs_all_to_all_get_src_rank()
int* cs_all_to_all_get_src_rank ( cs_all_to_all_t d)
This function should be called only after cs_all_to_all_copy_array, and allocates and returns an array of source element ranks matching the exchanged data elements.
It should also be called only if the distributor creation flags match CS_ALL_TO_ALL_NEED_SRC_RANK or CS_ALL_TO_ALL_ORDER_BY_SRC_RANK.
The returned data is owned by the caller, who is responsible for freeing it when no longer needed.
If source ranks are not available (depending on the distributor creation function and options), the matching pointer will be set to NULL.
[in]dpointer to associated all-to-all distributor
array of source ranks (or NULL)
◆ cs_all_to_all_get_type()
cs_all_to_all_type_t cs_all_to_all_get_type ( void  )
◆ cs_all_to_all_log_finalize()
void cs_all_to_all_log_finalize ( void  )
◆ cs_all_to_all_n_elts_dest()
cs_lnum_t cs_all_to_all_n_elts_dest ( cs_all_to_all_t d)
If no exchange has been done yet (depending on the communication protocol), metadata will be exchanged by this call, so it is a collective operation.
number of elements associated with distributor.
◆ cs_all_to_all_set_hybrid_parameters()
void cs_all_to_all_set_hybrid_parameters ( cs_rank_neighbors_exchange_t  rne_type)
[in]rne_typetype of metadata exchange algorithm
◆ cs_all_to_all_set_type()
void cs_all_to_all_set_type ( cs_all_to_all_type_t  t)
ttype of all-to-all distributor algorithm choice to select
◆ cs_all_to_all_transfer_dest_id()
void cs_all_to_all_transfer_dest_id ( cs_all_to_all_t d,
cs_lnum_t **  dest_id
The dest_id array should be the same as the one used for the creation of the distributor.
[in,out]dest_idpointer to element destination id
◆ cs_all_to_all_transfer_dest_rank()
void cs_all_to_all_transfer_dest_rank ( cs_all_to_all_t d,
int **  dest_rank
The dest_rank array should be the same as the one used for the creation of the distributor.
[in,out]dest_rankpointer to element destination rank
