cs_air_props.c File Reference
#include "cs_math.h"
#include "cs_air_props.h"
+ Include dependency graph for cs_air_props.c:
void cs_air_glob_properties_get_pointer (double **humidity0, double **cp_a, double **cp_v, double **cp_l, double **hv0, double **rho_l, double **lambda_h, double **lambda_l, double **droplet_diam)
cs_real_t cs_air_h_l (cs_real_t t_l)
 Calculation water mass enthalpy. More...
cs_real_t cs_air_hvap (cs_real_t t_vap)
 Calculation water vapor mass enthalpy. More...
cs_real_t cs_air_dxsath (cs_real_t th, cs_real_t p0)
 Calculation of the derivate of the absolute humidity at saturation. More...
cs_real_t cs_air_cp_humidair (cs_real_t x, cs_real_t x_s)
 Calculation of the Cp of humid air. More...
cs_real_t cs_air_h_humidair (cs_real_t cp_h, cs_real_t x, cs_real_t x_s, cs_real_t t_h)
 Calculation of the specific enthalpy of humid air. More...
cs_real_t cs_air_t_humidair (cs_real_t cp_h, cs_real_t x, cs_real_t x_s, cs_real_t h_h)
 Calculation of the temperature of humid air. More...
cs_real_t cs_liq_h_to_t (cs_real_t h_l)
 Calculation of the temperature of liquid water. More...
cs_real_t cs_liq_t_to_h (cs_real_t t_l)
 Calculation of the specific enthalpy of liquid water. More...
cs_real_t cs_air_x_sat (cs_real_t t_c, cs_real_t p)
 Calculation of the air humidity at saturation for a given temperature. More...
cs_real_t cs_air_yw_sat (cs_real_t t_c, cs_real_t p)
 Calculation of the air water mass fraction at saturation for a given temperature. More...
cs_real_t cs_air_pwv_sat (cs_real_t t_c)
 Computes the saturation water vapor pressure function of the temperature (in Celsius) More...
cs_real_t cs_air_x_to_yw (cs_real_t x)
 Convert the absolute humidity of humid air to the air water mass fraction qwt = Ym = mw/mh. More...
cs_real_t cs_air_yw_to_x (cs_real_t qw)
 Convert the air water mass fraction qwt = Ym = mw/mh to the absolute humidity of humid air. More...
void cs_rho_humidair (cs_real_t ywm, cs_real_t t_liq, cs_real_t p, cs_real_t *yw_liq, cs_real_t *t_h, cs_real_t *rho_h)
 Calculation of the density of humid air. More...
cs_real_t cs_air_rho_humidair (cs_real_t x, cs_real_t rho0, cs_real_t p0, cs_real_t t0, cs_real_t molmassrat, cs_real_t t_h)
cs_air_fluid_props_tcs_glob_air_props = &_props
◆ cs_air_cp_humidair()
cs_real_t cs_air_cp_humidair ( cs_real_t  x,
cs_real_t  x_s
specific heat of humid air
[in]xabsolute humidity of humid air
[in]x_sabsolute humidity of saturated humid air
◆ cs_air_dxsath()
cs_real_t cs_air_dxsath ( cs_real_t  th,
cs_real_t  p0
derivative of the humidity of saturated air
[in]thtemperature in Celsius degree
[in]p0reference pressure
◆ cs_air_glob_properties_get_pointer()
void cs_air_glob_properties_get_pointer ( double **  humidity0,
double **  cp_a,
double **  cp_v,
double **  cp_l,
double **  hv0,
double **  rho_l,
double **  lambda_h,
double **  lambda_l,
double **  droplet_diam
◆ cs_air_h_humidair()
cs_real_t cs_air_h_humidair ( cs_real_t  cp_h,
cs_real_t  x,
cs_real_t  x_s,
cs_real_t  t_h
[in]cp_hCp of humid air
[in]t_htemperature of humid air in Celsius
◆ cs_air_h_l()
cs_real_t cs_air_h_l ( cs_real_t  t_l)
Liquid water mass enthalpy
[in]t_lwater temperature in Celsius degree
◆ cs_air_hvap()
cs_real_t cs_air_hvap ( cs_real_t  t_vap)
[in]t_vapwater vapor temperature in Celsius
◆ cs_air_pwv_sat()
cs_real_t cs_air_pwv_sat ( cs_real_t  t_c)
the saturation water vapor pressure (=esatliq)
[in]t_ctemperature in Celsius degree
◆ cs_air_rho_humidair()
cs_real_t cs_air_rho_humidair ( cs_real_t  x,
cs_real_t  rho0,
cs_real_t  p0,
cs_real_t  t0,
cs_real_t  t_h
[in]rho0reference density of humid air
[in]t0reference temperature of humid air
[in]molmassratdry air to water vapor molecular mass ratio
◆ cs_air_t_humidair()
cs_real_t cs_air_t_humidair ( cs_real_t  cp_h,
cs_real_t  x,
cs_real_t  x_s,
cs_real_t  h_h
temperature of humid air (in Celsius)
[in]h_hhumid air enthalpy
◆ cs_air_x_sat()
cs_real_t cs_air_x_sat ( cs_real_t  t_c,
cs_real_t  p
absolute humidity of saturated air
[in]preference pressure
◆ cs_air_x_to_yw()
cs_real_t cs_air_x_to_yw ( cs_real_t  x)
◆ cs_air_yw_sat()
cs_real_t cs_air_yw_sat ( cs_real_t  t_c,
cs_real_t  p
◆ cs_air_yw_to_x()
cs_real_t cs_air_yw_to_x ( cs_real_t  qw)
[in]qwair water mass fraction
◆ cs_liq_h_to_t()
cs_real_t cs_liq_h_to_t ( cs_real_t  h_l)
liquid water temperature (in Celsius)
[in]h_lspecific enthalpy of liquid water
◆ cs_liq_t_to_h()
cs_real_t cs_liq_t_to_h ( cs_real_t  t_l)
[in]t_lliquid water temperature (in Celsius)
◆ cs_rho_humidair()
void cs_rho_humidair ( cs_real_t  ywm,
cs_real_t  t_liq,
cs_real_t  p,
cs_real_t yw_liq,
cs_real_t t_h,
cs_real_t rho_h
[in]ywmair water mass fraction
[in]t_liqtemperature computed from liquid potential temperature (K)
[in]ppressure
[out]yw_liqliquid water mass fraction
[out]t_htemperature of humid air in Celsius
[out]rho_hdensity of humid air
◆ cs_glob_air_props
cs_air_fluid_props_t* cs_glob_air_props = &_props
