#include "cs_defs.h"#include <assert.h>#include <math.h>#include <stdarg.h>#include <stdlib.h>#include <stdio.h>#include <string.h>#include "bft_error.h"#include "bft_mem.h"#include "bft_printf.h"#include "cs_physical_properties.h"#include "cs_eos.hxx"#include "cs_coolprop.hxx"
| void | cs_thermal_table_set (const char *material, const char *method, const char *reference, cs_phys_prop_thermo_plane_type_t thermo_plane, int temp_scale) |
| Define thermal table. More... | |
| void | cs_thermal_table_finalize (void) |
| finalize thermal table. More... | |
| void | cs_phys_prop_compute (cs_phys_prop_type_t property, cs_lnum_t n_vals, cs_lnum_t var1_stride, cs_lnum_t var2_stride, const cs_real_t var1[], const cs_real_t var2[], cs_real_t val[]) |
| Compute a physical property. More... | |
| void | cs_phys_prop_freesteam (cs_phys_prop_thermo_plane_type_t thermo_plane, cs_phys_prop_type_t property, const cs_lnum_t n_vals, const cs_real_t var1[], const cs_real_t var2[], cs_real_t val[]) |
| Compute properties with Freesteam in a defined thermal plane. More... | |
| void cs_phys_prop_compute | ( | cs_phys_prop_type_t | property, |
| cs_lnum_t | n_vals, | ||
| cs_lnum_t | var1_stride, | ||
| cs_lnum_t | var2_stride, | ||
| const cs_real_t | var1[], | ||
| const cs_real_t | var2[], | ||
| cs_real_t | val[] | ||
For values var1 and var2, we can use a stride so that accesses for a given element with id i will be of the form: var[i*stride]; this allows regular access with stride 1, and access to constant variables stored as a single-valued array with a stride of 0.
| [in] | property | property queried |
| [in] | n_vals | number of values |
| [in] | var1_stride | stride between successive values of var1 |
| [in] | var2_stride | stride between successive values of var2 |
| [in] | var1 | values on first plane axis |
| [in] | var2 | values on second plane axis |
| [out] | val | resulting property values |
| void cs_phys_prop_freesteam | ( | cs_phys_prop_thermo_plane_type_t | thermo_plane, |
| cs_phys_prop_type_t | property, | ||
| const cs_lnum_t | n_vals, | ||
| [in] | thermo_plane | thermodynamic plane |
| void cs_thermal_table_finalize | ( | void | ) |
| void cs_thermal_table_set | ( | const char * | material, |
| const char * | method, | ||
| const char * | reference, | ||
| cs_phys_prop_thermo_plane_type_t | thermo_plane, | ||
| int | temp_scale | ||
