#include "cs_defs.h"#include <assert.h>#include <errno.h>#include <stdio.h>#include <string.h>#include <math.h>#include "bft_mem.h"#include "bft_printf.h"#include "fvm_defs.h"#include "fvm_io_num.h"#include "cs_join_util.h"#include "cs_file.h"#include "cs_mesh.h"#include "cs_order.h"#include "cs_search.h"#include "cs_sort.h"#include "cs_join_set.h"
| cs_join_t * | cs_join_create (int join_number, const char *sel_criteria, float fraction, float plane, fvm_periodicity_type_t perio_type, double perio_matrix[3][4], int verbosity, int visualization, bool preprocessing) |
| void | cs_join_destroy (cs_join_t **join) |
| cs_join_select_t * | cs_join_select_create (const char *selection_criteria, fvm_periodicity_type_t perio_type, int verbosity) |
| void | cs_join_select_destroy (cs_join_param_t param, cs_join_select_t **join_select) |
| void | cs_join_extract_vertices (cs_lnum_t n_select_faces, const cs_lnum_t *select_faces, const cs_lnum_t *f2v_idx, const cs_lnum_t *f2v_lst, cs_lnum_t n_vertices, cs_lnum_t *n_select_vertices, cs_lnum_t *select_vertices[]) |
| void | cs_join_clean_selection (cs_lnum_t *n_elts, cs_lnum_t *elts[], cs_lnum_t n_ref_elts, cs_lnum_t ref_elts[]) |
| void | cs_join_build_edges_idx (cs_lnum_t n_faces, const cs_lnum_t faces[], const cs_lnum_t f2v_idx[], const cs_lnum_t f2v_lst[], cs_lnum_t v2v_idx[]) |
| void | cs_join_build_edges_lst (cs_lnum_t n_faces, const cs_lnum_t faces[], const cs_lnum_t f2v_idx[], const cs_lnum_t f2v_lst[], cs_lnum_t count[], const cs_lnum_t v2v_idx[], cs_lnum_t v2v_lst[]) |
| void cs_join_build_edges_idx | ( | cs_lnum_t | n_faces, |
| const cs_lnum_t | faces[], | ||
| const cs_lnum_t | f2v_idx[], | ||
| const cs_lnum_t | f2v_lst[], | ||
| cs_lnum_t | v2v_idx[] | ||
| void cs_join_build_edges_lst | ( | cs_lnum_t | n_faces, |
| cs_lnum_t | count[], | ||
| const cs_lnum_t | v2v_idx[], | ||
| cs_lnum_t | v2v_lst[] | ||
| void cs_join_clean_selection | ( | cs_lnum_t * | n_elts, |
| cs_lnum_t * | elts[], | ||
| cs_lnum_t | n_ref_elts, | ||
| cs_lnum_t | ref_elts[] | ||
| cs_join_t* cs_join_create | ( | int | join_number, |
| const char * | sel_criteria, | ||
| float | fraction, | ||
| float | plane, | ||
| fvm_periodicity_type_t | perio_type, | ||
| double | perio_matrix[3][4], | ||
| int | verbosity, | ||
| int | visualization, | ||
| bool | preprocessing | ||
| void cs_join_destroy | ( | cs_join_t ** | join | ) |
| void cs_join_extract_vertices | ( | cs_lnum_t | n_select_faces, |
| const cs_lnum_t * | select_faces, | ||
| const cs_lnum_t * | f2v_idx, | ||
| const cs_lnum_t * | f2v_lst, | ||
| cs_lnum_t | n_vertices, | ||
| cs_lnum_t * | n_select_vertices, | ||
| cs_lnum_t * | select_vertices[] | ||
| cs_join_select_t* cs_join_select_create | ( | const char * | selection_criteria, |
| int | verbosity | ||
| void cs_join_select_destroy | ( | cs_join_param_t | param, |
| cs_join_select_t ** | join_select | ||
