#include "cs_defs.h"#include <assert.h>#include <stdio.h>#include <string.h>#include "bft_mem.h"#include "fvm_io_num.h"#include "cs_all_to_all.h"#include "cs_block_dist.h"#include "cs_join_util.h"#include "cs_order.h"#include "cs_search.h"#include "cs_sort.h"#include "cs_join_set.h"
| cs_join_rset_t * | cs_join_rset_create (cs_lnum_t max_size) |
| void | cs_join_rset_destroy (cs_join_rset_t **set) |
| void | cs_join_rset_resize (cs_join_rset_t **set, cs_lnum_t test_size) |
| cs_join_eset_t * | cs_join_eset_create (cs_lnum_t init_size) |
| void | cs_join_eset_check_size (cs_lnum_t request_size, cs_join_eset_t **equiv_set) |
| void | cs_join_eset_destroy (cs_join_eset_t **equiv_set) |
| void | cs_join_eset_clean (cs_join_eset_t **eset) |
| cs_join_gset_t * | cs_join_gset_create (cs_lnum_t n_elts) |
| cs_join_gset_t * | cs_join_gset_create_from_tag (cs_lnum_t n_elts, const cs_gnum_t tag[]) |
| cs_join_gset_t * | cs_join_gset_create_by_equiv (const cs_join_gset_t *set, const cs_gnum_t init_array[]) |
| cs_join_gset_t * | cs_join_gset_copy (const cs_join_gset_t *src) |
| void | cs_join_gset_destroy (cs_join_gset_t **set) |
| void | cs_join_gset_sort_elts (cs_join_gset_t *set) |
| void | cs_join_gset_sort_sublist (cs_join_gset_t *set) |
| cs_join_gset_t * | cs_join_gset_invert (const cs_join_gset_t *set) |
| void | cs_join_gset_clean (cs_join_gset_t *set) |
| void | cs_join_gset_clean_from_array (cs_join_gset_t *set, cs_gnum_t linked_array[]) |
| void | cs_join_gset_single_order (const cs_join_gset_t *set, cs_lnum_t *n_elts, cs_gnum_t *new_array[]) |
| void | cs_join_gset_compress (cs_join_gset_t *set) |
| void | cs_join_gset_merge_elts (cs_join_gset_t *set, int order_tag) |
| void | cs_join_dump_array (FILE *f, const char *type, const char *header, int n_elts, const void *array) |
| void | cs_join_gset_dump (FILE *f, const cs_join_gset_t *set) |
| void cs_join_dump_array | ( | FILE * | f, |
| const char * | type, | ||
| const char * | header, | ||
| int | n_elts, | ||
| const void * | array | ||
| void cs_join_eset_check_size | ( | cs_lnum_t | request_size, |
| cs_join_eset_t ** | equiv_set | ||
| void cs_join_eset_clean | ( | cs_join_eset_t ** | eset | ) |
| cs_join_eset_t* cs_join_eset_create | ( | cs_lnum_t | init_size | ) |
| void cs_join_eset_destroy | ( | cs_join_eset_t ** | equiv_set | ) |
| void cs_join_gset_clean | ( | cs_join_gset_t * | set | ) |
| void cs_join_gset_clean_from_array | ( | cs_join_gset_t * | set, |
| cs_gnum_t | linked_array[] | ||
| void cs_join_gset_compress | ( | cs_join_gset_t * | set | ) |
| cs_join_gset_t* cs_join_gset_copy | ( | const cs_join_gset_t * | src | ) |
| cs_join_gset_t* cs_join_gset_create | ( | cs_lnum_t | n_elts | ) |
| cs_join_gset_t* cs_join_gset_create_by_equiv | ( | const cs_join_gset_t * | set, |
| const cs_gnum_t | init_array[] | ||
| void cs_join_gset_destroy | ( | cs_join_gset_t ** | set | ) |
| void cs_join_gset_dump | ( | FILE * | f, |
| const cs_join_gset_t * | set | ||
| cs_join_gset_t* cs_join_gset_invert | ( | const cs_join_gset_t * | set | ) |
| void cs_join_gset_merge_elts | ( | cs_join_gset_t * | set, |
| int | order_tag | ||
| void cs_join_gset_single_order | ( | const cs_join_gset_t * | set, |
| cs_lnum_t * | n_elts, | ||
| cs_gnum_t * | new_array[] | ||
| void cs_join_gset_sort_elts | ( | cs_join_gset_t * | set | ) |
| void cs_join_gset_sort_sublist | ( | cs_join_gset_t * | set | ) |
| cs_join_rset_t* cs_join_rset_create | ( | cs_lnum_t | max_size | ) |
| void cs_join_rset_destroy | ( | cs_join_rset_t ** | set | ) |
| void cs_join_rset_resize | ( | cs_join_rset_t ** | set, |
| cs_lnum_t | test_size | ||
