Hello, I use the ALE method to study the problem of interaction fluid structureand this is the file TET.Cylindre.xml. When I execute the calculation, I get the following error message on the terminal and the calculation stops:
code_saturne is running
Version: 2.1.0
Path: /local00/alsayed/Code_Saturne_2.1.0/code_saturne-2.1.0
Result directory:
/local00/STUDY/CYLINDRE/RESU/20111122-1320
Single processor code_saturne simulation.
Preparing calculation data
Preprocessing calculation
Starting calculation
Fortran runtime error: Internal: Attempt to DEALLOCATE unallocated memory.
solver script exited with status 2.
Saving calculation results
Error in calculation stage.
Do you have an idea to unlock the problem ?
Thank you in advance
Nazir.
Problem with ALE
Nazir Al Sayed
Problem with ALE
- TET_Cylindre.xml
- (7.52 KiB) Downloaded 311 times
- listing.txt
- (31.71 KiB) Downloaded 336 times
Mickael Hassanaly
Re: Problem with ALE
Hi Nazir,
In your listing file, You have the following warning message :
Code_Saturne : /home/alsayedn/Desktop/Logiciels/installer/code_saturne-2.1.0/src/base/cs_selector.c:356 : Avertissement
Le groupe ou attribut "6" figurant dans le
critère de sélection:
"6"
ne correspond à aucune face de bord.
This should be your problem. Have you got any fortran routine?
Mickaël
"6"
Mickaël
Nazir Al Sayed
Yes I have all the Fortran file .. / src /base/
For cons, I did not use the files for the following FORTRAN modules ALE: usstru.f90, usalin.f90 usalcl.f90. I use directly the GUI to impose the ALE method parameters (see attached file cylindre.xml)
I solved the problem I had on the old file listing (attached the new file listing), but I still the same error message:
On the forum, there is an example of the method ALE set palces by Alexander Douce. (http://code-saturne.org/forum/viewtopic.php?f=10&t=945). even this example does not work, same error message.
Do I have to also use the following file: usstru.f90, usalin.f90 usalcl.f90 to impose the ALE method parameters?
Thank you.
Nazir.
Thank you.
Nazir.
- listing.txt
- (31.83 KiB) Downloaded 313 times
- cylinder.xml
- (8.57 KiB) Downloaded 316 times
Mickael Hassanaly
Hi Nazir,
You can't just take the example given by Alexandre because you didn't use the same version of Code_Saturne. You have to fill it manually for Code_Saturne 2.1.0.
Mickaël
Mickaël
Once you have updated (rebuilt) your setup/xml file, if the error persists, could you post the xml along with the mesh ? As dynamic memory management was a major change in version 2.1, there may still be a few bugs, so we could re-test your case.
Nazir Al Sayed
I placed all the parameters for the fluid-strucutre in the following files: usstru.f90, usalin.f90 & usalcl.f90.
I have always the same error message:
Version: 2.1.0
Result directory:
/local00/STUDY/CAS3/RESU/20111123-1700
Version: 2.1.0
Result directory:
- usstru.f90
- (17.44 KiB) Downloaded 328 times
- usalin.f90
- (4.11 KiB) Downloaded 324 times
- usalcl.f90
- (20.97 KiB) Downloaded 321 times
David Monfort
I've recently faces the same problem of memory deallocation.
This will be fixed in a 2.1.1 version that should soon be released.
David
David
