Problem with ALE
Nazir Al Sayed
Problem with ALE
Post by Nazir Al Sayed »
Hello, I use the ALE method to study the problem of interaction fluid structureand this is the file TET.Cylindre.xml. When I execute the calculation, I get the following error message on the terminal and the calculation stops:
 code_saturne is running
 Version: 2.1.0
 Path:    /local00/alsayed/Code_Saturne_2.1.0/code_saturne-2.1.0
 Result directory:
   /local00/STUDY/CYLINDRE/RESU/20111122-1320
 Single processor code_saturne simulation.
  Preparing calculation data
  Preprocessing calculation
  Starting calculation
Fortran runtime error: Internal: Attempt to DEALLOCATE unallocated memory.
 solver script exited with status 2.
  Saving calculation results
 Error in calculation stage.
Do you have an idea to unlock the problem ?
Thank you in advance
Nazir.
TET_Cylindre.xml
(7.52 KiB) Downloaded 250 times
listing.txt
(31.71 KiB) Downloaded 241 times
Mickael Hassanaly
Re: Problem with ALE
Post by Mickael Hassanaly »
Hi Nazir,
In your listing file, You have the following warning message :
Code_Saturne : /home/alsayedn/Desktop/Logiciels/installer/code_saturne-2.1.0/src/base/cs_selector.c:356 : Avertissement
Le groupe ou attribut "6" figurant dans le
critère de sélection:
"6"
 ne correspond à aucune face de bord.
This should be your problem. Have you got any fortran routine?
Mickaël
Nazir Al Sayed
Yes I have all the Fortran file .. / src /base/
For cons, I did not use the files for the following FORTRAN modules ALE: usstru.f90,  usalin.f90 usalcl.f90.  I use directly the GUI to impose the ALE method parameters (see attached file cylindre.xml)
I solved the problem I had on the old file listing (attached the new file listing), but I still the same error message:
On the forum, there is an example of the method ALE set palces by Alexander Douce. (http://code-saturne.org/forum/viewtopic.php?f=10&t=945). even this example does not work, same error message.
Do I have to also use the following file: usstru.f90,  usalin.f90 usalcl.f90  to impose the ALE method parameters?
Thank you.
Nazir.
listing.txt
(31.83 KiB) Downloaded 250 times
cylinder.xml
(8.57 KiB) Downloaded 279 times
Mickael Hassanaly
Hi Nazir,
You can't just take the example given by Alexandre because you didn't use the same version of Code_Saturne. You have to fill it manually for Code_Saturne 2.1.0.
Mickaël
Once you have updated (rebuilt) your setup/xml file, if the error persists, could you post the xml along with the mesh ? As dynamic memory management was a major change in version 2.1, there may still be a few bugs, so we could re-test your case.
Nazir Al Sayed
I placed all the parameters for the fluid-strucutre in the following files: usstru.f90, usalin.f90 & usalcl.f90.
I have always the same error message:
Version: 2.1.0
Result directory:
/local00/STUDY/CAS3/RESU/20111123-1700
usstru.f90
(17.44 KiB) Downloaded 259 times
usalin.f90
(4.11 KiB) Downloaded 265 times
usalcl.f90
(20.97 KiB) Downloaded 257 times
David Monfort
Post by David Monfort »
I've recently faces the same problem of memory deallocation.
This will be fixed in a 2.1.1 version that should soon be released.
David
