MESH of complex geometry
sophie Lu
Post by sophie Lu »
I want to process complex urban ground as a MESH simulation. Now I have generate MESH of buildings successfully from DSM file. In this case, how can I extract the air area above the city? I have tried to generated a box that can cover the buildings and do Boolean cut, but it always warning that "cut cannot produce".
Is there any reference example or suggestion?
Thanks for your help!
Sophie
louis.simvia
Re: MESH of complex geometry
Post by louis.simvia »
What software are you using to generate the mesh ?
According to what I understood, if you are using Salome shaper module to make the geometry, here is a video of how to make the mesh of the fluid domain around a house. You may find some tips that are related to current issue.
Let me know if this helps.
sophie Lu
Post by sophie Lu »
Hi Louis,
Thanks for your reply. I want to generate multiple buildings and do some simulation about air pollution. I am using geometry and my MESH can be generated by using NETGEN 1D-2D-3D, but the model always said mesh quality is not good. I know its better to generate the mesh as hexahedral, but since my geometry has multiple buildings which means has multiple shells, it can not process to be hexahedral. Do you have any advice for this shpe process?Thanks!
Which model are you referring to in
? If you are using code_saturne's mesh quality check, keep in mind that the indications are not "absolute". Quality issues detected may make it harder to converge and lead to a less stable computation, but there is no fixed/known threshold where the computation can or cannot run. The main idea is to visualize the quality criteria to determine where you could improve the mesh.
When using a mesh with tetrahedra, adding a viscous/boundary prisms layer, and extruding the mesh a bit at outlets can definitely help make the computation more stable.
sophie Lu
Post by sophie Lu »
Thanks for your reply. According to the complex geometry and mesh processes, I heard that Code Saturne 9.0 can generate MESH from csv/pts file, is that possible? I have checked the function list, there is a function named 'cs_user_mesh_cartesian_define function':
/* Create a mesh based on a CSV file containing vertices coordinates
* for each direction.
* CSV file needs to contain :
* (1) First line which is empty or contains a header
* (2) Second line containing number of vertices per direction:
* format is 'nx;ny;nz'
* (3) Third line is empty or contains a header
* (4) Fourth line and onwards contains vertices coordinates for each
* direction. Format is "X1;X2;X3" for index i.
* If current vertex index is beyond max value for a given
* direction, an empty value is expected.
* For example, if for index 'j' the first direction is empty,
* format is : ';X2[j];X3[j]'
cs_mesh_cartesian_define_from_csv("nullptr", /* No defined name for this mesh */
"cartesian_vertex_coordinates.csv");
Can this function make a mesh from files?
Thanks,
Sophie
I have not tested the cs_mesh_cartesian_define_from_csv function, but I guess you could try it.
In a test case I am more familiar with, cs_mesh_cartesion_define_simple is used(and this could even be done through the GUI), and in cs_user_parameters,,
cs_glob_porosity_ibm_opt->porosity_mode = CS_IBM_FIXED_SOLID;
must be set.
Additional settings for IBM are shown in user_examples/cs_user_ibm.cpp. See the user examples in cs_user_ibm_define_objects and cs_user_ibm_parameters functions for options. Check those files direclty in the source tree (https://github.com/code-saturne/code_sa ... er_ibm.cpp), as the examples do not seem indexed under the html (Doxygen-based) documentation.
I assume cs_mesh_cartesian_define_from_csv function combines several operations, but doing this with the stages above should work also.
In all cases, whether using a scan of points or an STL file, this is an "Immersed Boundary Method" approach. In v9.1, or v9.2 it may be possible to really define a mesh with cut cells by taking this one step further.
sophie Lu
Post by sophie Lu »
I have updated my mesh study and I want to comfirm with you if I am doing this right.
By using these lines in cs_user_parameters.c, a pts file can be read into the MESH:
void
cs_user_model(void)
cs_porosity_from_scan_set_file_name("pointcloud_Chelsea_newref.pts");
cs_porosity_from_scan_set_output_name("mesh");
It seems worked fine with "Add file pointcloud_Chelsea_newref.pts to the list pointcloud_Chelsea_newref.pts;" in the log file.
The results include two new case files: MESH_00.case and IB_MESH.case, the purpose of which I do not fully understand. In addition, in the RESULTS_FLUID_DOMAIN.case, there are several new variables such as porosity, porosity_holes, and nb_scan_points. The porosity-related results appear unusual, and their spatial distribution does not resemble the building geometry. Is this behavior expected?
Could you please help me to check if the study is right? I have attached the run_solver.log. and my domain setting.
Thanks again for your guidance!
Best
Sophie
run_solver.log
(275.09 KiB) Downloaded 1078 times
The MESH_00.case and IB_MESH.case should help you visualize whether the immersed boundary is where you expect it. Actually, in the master branch (since revision fa9358ab, last friday), you can also visualize the faces where cells are cut, by calling;
cs_porous_model_enable_post();
in cs_user_parameters.cpp.
Porosity should be 1 in fluid areas, 0 in solid areas, and have intermediate values in cut cells. Does it seem OK when you visualize it ?
I know that on complex cases, when insufficient data (i.e. scanned points) is present to build a mean plane intersecting some cells, some badly oriented cut planes can occur, an need additional filtering, though I am not quite sure how this is done. I can check with the colleagues developing this.
Samuel
Post by Samuel »
Hello Sophie,
I see that your point cloud (the .pts file) is lacking information and contains only 53 points to represent your buildings (in run_solver.log: "Porosity from scan: 53 points to be read"). Remember that you need at least 3 scan points per cell to build a plane.
The normal to the plane in a cell must be oriented from the fluid part towards the solid part (typically inside the building). To ensure the correct orientation, we mimic what a real scanner placed in the fluid part would do by sending rays to the buildings. Currently, in the run_solver.log, you have "Positions of the 0 given sources". You need to add the position of some scanners around the buildings. You can put a CSV file in the DATA folder containing the positions in x,y,z format and call it in your cs_user_parameters:
const char *csv_file_path = "posi_scan.csv"; // See my PJ, i put 2 scanners at arbitrary position
cs_ibm_add_sources_by_file_name(csv_file_path);
I hope this will help you. Best regards.
posi_scan.csv
(61 Bytes) Downloaded 1053 times
sophie Lu
Post by sophie Lu »
Hi Yvan and Samuel,
Thanks for your guidance and the pts file has been read fine. Thanks!
Sophie
