Hello Code_Saturne users!
I'm facing a problem while trying to run the 3_2D_DISKS coupled case and I believe it's an installation/set-up problem (both Saturne and Syrthes are running independently). Already tried to figure it out by myself and with the forum but everything I tried so far did not work.
When I run "code_saturne run" in the case directory, I get the attached message ("Terminal" file).
I'm using a virtual ubuntu 22.04 machine with Oracle VM virtual box.
I've also attached Saturne and Syrthes install log, setup.ini for Syrthes, setup_ini for Saturne and code saturne cfg.
Note that I had Syrthes already installed, then I installed Saturne with link to Syrthes hdf5 and med, then reinstalled Syrthes with Saturne ple path (Yes, that's a bit ugly! the problem might be related to that?).
Thanks for your help!
[SOLVED] KeyError: 'syrthes': Problem coupling Saturne 8.02/Syrthes5.0
- setup.ini
- (4.37 KiB) Downloaded 6553 times
- install_saturne.log
- (1.44 MiB) Downloaded 6745 times
- Terminal.txt
- (2.78 KiB) Downloaded 6477 times
Re: KeyError: 'syrthes': Problem coupling Saturne 8.02/Syrthes5.0
Other attachments that did not fit in the previous message.
- setup_ini.txt
- (4.08 KiB) Downloaded 6526 times
- ERREUR.log
- (8.39 KiB) Downloaded 6497 times
- code_saturne.cfg.txt
- (3.87 KiB) Downloaded 6551 times
For the Syrthes confing in code_saturne.cfg, you need to uncomment the line containing the Syrthes path. Hope that does the trick.
Hello Yvan, and thank you for the lightning-fast response.
That working well now. I can't figure out how I missed that while reviewing the config files so many times...
At least I hope it can help others.
Thanks!
Thanks!
