[SOLVED] KeyError: 'syrthes': Problem coupling Saturne 8.02/Syrthes5.0
PNM
Post by PNM »
Hello Code_Saturne users!
I'm facing a problem while trying to run the 3_2D_DISKS coupled case and I believe it's an installation/set-up problem (both Saturne and Syrthes are running independently). Already tried to figure it out by myself and with the forum but everything I tried so far did not work.
When I run "code_saturne run" in the case directory, I get the attached message ("Terminal" file).
I'm using a virtual ubuntu 22.04 machine with Oracle VM virtual box.
I've also attached Saturne and Syrthes install log, setup.ini for Syrthes, setup_ini for Saturne and code saturne cfg.
Note that I had Syrthes already installed, then I installed Saturne with link to Syrthes hdf5 and med, then reinstalled Syrthes with Saturne ple path (Yes, that's a bit ugly! the problem might be related to that?).
Thanks for your help!
setup.ini
(4.37 KiB) Downloaded 6179 times
install_saturne.log
(1.44 MiB) Downloaded 6388 times
Terminal.txt
(2.78 KiB) Downloaded 6115 times
PNM
Re: KeyError: 'syrthes': Problem coupling Saturne 8.02/Syrthes5.0
Post by PNM »
Other attachments that did not fit in the previous message.
setup_ini.txt
(4.08 KiB) Downloaded 6192 times
ERREUR.log
(8.39 KiB) Downloaded 6172 times
code_saturne.cfg.txt
(3.87 KiB) Downloaded 6244 times
For the Syrthes confing in code_saturne.cfg, you need to uncomment the line containing the Syrthes path. Hope that does the trick.
PNM
Post by PNM »
Hello Yvan, and thank you for the lightning-fast response.
That working well now. I can't figure out how I missed that while reviewing the config files so many times...
At least I hope it can help others.
Thanks!
