Disable exporting a field in post-processing stage
Mohammad
Post by Mohammad »
As you know all user defined fields values will be exported in a specific file (with .0001 extension) in post-processing stage which may occupy a lot of disk space specially for clusters which there is only a very limited disks pace available for user.
Is there an option to disable this feature for some user defined fields which don't need to be exported as a file?
Mohammad
Re: Disable exporting a field in post-processing stage
Check for "Postprocessing output" in https://www.code-saturne.org/cms/sites/ ... eters.html, adjust for the field name, and replace CS_POST_MONITOR with "0".
In other words:
  cs_field_set_key_int_bits(cs_field_by_name("user_field"),
                           cs_field_key_id("post_vis"),
                           0);
Mohammad
Post by Mohammad »
Thank you very much Mr. Yvan Fournier.
Mohammad
