As you know all user defined fields values will be exported in a specific file (with .0001 extension) in post-processing stage which may occupy a lot of disk space specially for clusters which there is only a very limited disks pace available for user.
Is there an option to disable this feature for some user defined fields which don't need to be exported as a file?
Mohammad
Disable exporting a field in post-processing stage
Re: Disable exporting a field in post-processing stage
Check for "Postprocessing output" in https://www.code-saturne.org/cms/sites/ ... eters.html, adjust for the field name, and replace CS_POST_MONITOR with "0".
In other words:
In other words:
cs_field_set_key_int_bits(cs_field_by_name("user_field"),
cs_field_key_id("post_vis"),
0);
Thank you very much Mr. Yvan Fournier.
Mohammad
Mohammad
