Hello
I am trying to calculate with parallel processes on Ubuntu 18.04
I am using CS 5.2 in Salome CFD
To do so, I installed the package libopenmpi-dev
However, I obtained the following error message
Could you pls explain me ?
Thank you very much,
best regards
Jérémy
Error in parallelization in Saturne 5.2
- Error.log
- (5.38 KiB) Downloaded 236 times
Re: Error in parallelization in Saturne 5.2
The MPI version in the "universal" build probably does not match that of Ubuntu 18.04. The solution would be to recompile code_saturne (while using the Sslome libraries). Basically, the same thing you tried before except for the --with-salome option, which you can avoid for now (or add --without-salome).
Though if you need Syrthes coupling you would need to recompile that too....
