Hello everyone,
I use Code_saturne 4.3, but there is no folder named checkpoint or partition, is this a problem of a software version? How can I restart a simulation after a sudden kill of the previous process.
Jiawei
A question about checkpoint
Re: A question about checkpoint
There should be a checkpoint. Perhaps the run was killed before the first checkpoint was written ?
Hello Yvans,
Thanks for your answer, but there is still no file named partition_output either in the end of simulation nor in process of simulation, I would like to know how to restart a simulation in this condition, if I can't, what should I do to solve this problem,
In addition, in the file postprocess generated by the version CS4.3, there are only results.0001(for example: results.pressure 0001 and results temperature 0001 etc). But in the previous results simulated by the version 4.0.2, I can find the results from 0001 to 00020. why does this difference appears and is there any problem?
Jiawei
Jiawei
Without more info (such as that in the forum recommendations); it is hard to guess at the causes of these issues.
