I am using Salome 7.2.0 (because I have Ubunto 15.04 with 32 bit) and Code_saturne 4.2. I am doing Tutorial 1: Shear Driven Cavity Flow.
I am exporting the mesh as CGNS file. I tried also for MED file.
I am just following the tutorial step by step. And I had this error.
Preparing calculation data
Preprocessing calculation
Starting calculation
Saving calculation results
Error in calculation stage.
Can you help me ? Thanks a lot
gdib
Re: Error in calculation stage.
Now I tried '' sudo ldconfig ''
and then I run it and always I have the same error.
Did you check the files mentioned in the error message (which are also mentioned in the forum recommendations) ?
