Rank pointer problem using uselrc.f90 CS4.0
Christophe Loubet
Post by Christophe Loubet »
Dear all,
I get the following error by using uselrc.f90 file with CS4.0:
cs_field.c:987: Erreur fatale
Fortran pointer of rank 2 requested for values of field "curent_re_1", which have rank 1.
It seems that the problem provides from the following call:
call field_get_val_v(iprpfl(idjr(idimve)),djr)
initialized as follows:
double precision, dimension(:,:), pointer :: djr
Could someone help me?
Christophe
Re: Rank pointer problem using uselrc.f90 CS4.0
The example seems to mix scalar and vector data (probably due to a previous try to move to vector representation, which was delayed).
Could you start from the following example instead ? Note this is an example only. Cases in the validation test suite do not use uselrc for rescaling (but mostly the GUI).
uselrc.f90
(13.03 KiB) Downloaded 270 times
Christophe Loubet
Dear Yvan Fourier,
It seems that it works well :D . Thank you really much.
Christophe
