Dear all,
I get the following error by using uselrc.f90 file with CS4.0:
cs_field.c:987: Erreur fatale
Fortran pointer of rank 2 requested for values of field "curent_re_1", which have rank 1.
It seems that the problem provides from the following call:
call field_get_val_v(iprpfl(idjr(idimve)),djr)
initialized as follows:
double precision, dimension(:,:), pointer :: djr
Could someone help me?
Christophe
Rank pointer problem using uselrc.f90 CS4.0
Re: Rank pointer problem using uselrc.f90 CS4.0
The example seems to mix scalar and vector data (probably due to a previous try to move to vector representation, which was delayed).
Could you start from the following example instead ? Note this is an example only. Cases in the validation test suite do not use uselrc for rescaling (but mostly the GUI).
- uselrc.f90
- (13.03 KiB) Downloaded 213 times
Dear Yvan Fourier,
It seems that it works well
. Thank you really much.
Christophe
Christophe
