Hello !
I am studying the code (v3.0) on a validation test case. It's a natural convection due to a heated cube in a large room. However, when I define a heat flux on the cube (positive value), the part which is located between the floor and the cube gets colder to -163°C when it should be around 28 !
I do not get such problems with other BC condition (fixed temperature, exchange coefficient, etc).
I tried several meshes, hex, tet with BL, etc...
Is it a bug or shoud the mesh be very refined or something else ?
Link to the case description :
https://www.google.fr/url?sa=t&rct=j&q= ... 8935,d.d2k
Heat Flux
Re: Heat Flux
I believe that the heat flux you define is the outgoing flux, by Code_Saturne's conventions.
Did you try inverting the sign ?
Alec
Re: Heat Flux
Thank you very much, it is now working properly.
It's my fault I was too sure about my interpretation of the conventions.
Alec
Alec
